packaging_projects
packaging_projects [2015/09/28 08:50]
packaging_projects [2015/09/28 08:51] (current)
admin [Notes]
Line 9: Line 9:
 To package a project, first open the project that you want to package. ​ Then open the GIS Editor [[Main Menu]] and select "​Package Project"​. To package a project, first open the project that you want to package. ​ Then open the GIS Editor [[Main Menu]] and select "​Package Project"​.
-You will be prompted with a standard Save As dialog, where you can choose the location and filename for your packaged Zip file.  Once you have done this, click the Save button and your project will be packaged and saved. ​ Any layer data that you have loaded into your project will be copied into a subfolder called //[[Project|Name]]_Data//, where [[Project|Name]] is the name of your project file.+You will be prompted with a standard Save As dialog, where you can choose the location and filename for your packaged Zip file.  Once you have done this, click the Save button and your project will be packaged and saved. ​ Any layer data that you have loaded into your project will be copied into a subfolder called //[Project Name]_Data//,​ where [Project Name] is the name of your project file.
 You are now free to distribute the resulting Zip file or move it to another computer. You are now free to distribute the resulting Zip file or move it to another computer.
Line 19: Line 19:
 Please be aware that if you have loaded many complex layers into your project, the packaged Zip file may be quite large (potentially tens or hundreds of megabytes, depending on your data). Please be aware that if you have loaded many complex layers into your project, the packaged Zip file may be quite large (potentially tens or hundreds of megabytes, depending on your data).
-[[Category:​General]]
packaging_projects.1443430211.txt.gz ยท Last modified: 2015/09/28 08:50 by admin
