map_suite_wpf_desktop_edition_layers_featuresources_samples
map_suite_wpf_desktop_edition_layers_featuresources_samples [2015/09/25 03:56]
-====== ​ Map Suite Wpf Desktop Edition Layers & FeatureSources Samples ​ ======
-<div sampleitem>​
-====  Native KML(Keyhole Markup Language) Support ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition KMLFile.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_KMLFile.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_KMLFile_141212.zip|C#​ Download}}
-<div sample_otherlinks>​
-[[Map Suite Samples Applies To|Applies To: Desktop \ Web \ Silverlight \ Wpf ]]
-In today'​s WPF project, we show you how to take advantage of Map Suite to load the Keyhole Markup Language (KML) file, which is an XML notation for expressing geographic annotation and visualization within Internet-based brwosers. With the latest KML support in Map Suite, you can eaisily display such files on a Map Suite control, including adorment pictures, placemarks etc. Also you can do the conversion between KML and any other vector formats supported by Map Suite componenets.
-<div sampleitem>​
-====  Apply Quick Filter to FeatureSource ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition QuickFilter LinkSource.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_QuickFilter_LinkSource.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_QuickFilter_LinkSource_141212.zip|C#​ Download}}
-In today'​s WPF project, we show you how to apply the quick filters to a FeatureSource with the help of  LinkSource and LinkExpressions. With the LinkExpreesion,​ we can specify the query string to determine which features will be displayed. This feature can be applied in all Map Suite products.
-<div sampleitem>​
-====  NOAA Global Weather Station ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample NOAA Global Weather Station.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_NOAAGlobelWeatherStationLayer.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_NOAAGlobelWeatherStationLayer_141212.zip|C#​ Download}}
-In today'​s WPF project, we show you how to query and display real time NOAA wather station data directly as a Layer, which allows you to display up-to-date weather station data from around the world on top of your maps. The weather station data is sourced from NOAA and is refreshed every 15 minutes in the background. As these classes are inherited from the FeatureSource and FeatureLayer,​ many properties are querable and can be used to create a variety of maps or analysis of current weather patterns. This feature can be applied in all Map Suite products.
-<div sampleitem>​
-====  Magnetic Declination ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Magnetic Declination.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_MagneticDeclination.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_MagneticDeclination_141212.zip|C#​ Download}}
-In today'​s WPF project, we show you how to add the Magnetic Declination or Magnetic variation to the map, it's designed as an AdormentLayer,​ which is used for showing the angle on the horizontal plane between magnetic north (the direction in which the north end of a compass needle, corresponding to the direction of the Earth'​s magnetic field lines) and true north (the direction along a meridian towards the geographic North Pole). This angle varies depending on one's position on the Earth'​s surface, and over time. See http://​en.wikipedia.org/​wiki/​Magnetic_declination for more details. This feature can be applied in all Map Suite products.
-<div sampleitem>​
-====  Delay Map Drawing Feature ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Delay Drawing.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_DelayDrawing.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_DelayDrawing_141212.zip|C#​ Download}}
-In this WPF project, we show you how to use the Delay Map Drawing feature to control whether or not redraw the layer after a specified delay. This option is very helpful for anyone wanting to do something before actually refresh the map, such as editing the elements, adding an animation etc. This effect can be avaible in all Map Suite products.
-<div sampleitem>​
-====  Combining Overlays ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Combining Overlays.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_CombiningOverlays_101011.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_CombiningOverlays_CS_101011.zip|C#​ Download}}
-<div sampleitem>​
-====  Create GRID  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Desktop Edition Sample Create GRID.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample CreateGRID CS 110512.zip|View Source]]
-{{:​File:​DesktopEditionSample CreateGRID CS 110512.zip|C#​ Download}}
-<div sampleitem>​
-====  Edit Attribute Of Shapefile ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Edit Attribute Of Shapefile.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_EditAttributeOfShapefile_CS_110306.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_EditAttributeOfShapefile_CS_110306.zip|C#​ Download}}
-<div sampleitem>​
-====  Edit Geometry Of Shapefile ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Desktop Edition Sample Edit Geometry Of Shapefile.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_EditGeometryOfShapefile_CS_101021.zip|View Source]]
-{{:​File:​DesktopEditionSample_EditGeometryOfShapefile_CS_101021.zip|C#​ Download}}
-<div sampleitem>​
-====  Get Data From Server With WCF  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​RequireDataFromServerUsingWcf.PNG?​300x180}}
-<div content>
-[[Source_Code_SilverlightEditionSample_GetDataFromServerWithWcf_CS.zip|View Source]]
-In this Silverlight-based project, we are going to take a look at how to get geometry data from the server side using the WCF service with Map Suite Silverlight Edition, while keeping all map data on the server side. You can click any of the countries on the map to call a WCF service, which will require data from the server, and then a popup will appear with information about that country.
-<div sampleitem>​
-====  Graphic Logo Adornment Layer  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Graphic Logo Adornment Layer.png?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_GraphicLogoAdornmentLayer_CS_100128.zip|View Source]]
-{{:​File:​DesktopEditionSample_GraphicLogoAdornmentLayer_CS_100128.zip|C#​ Download}}
-[[Map Suite Samples Applies To|Applies To: Desktop \ Services \ Wpf ]]
-This sample shows how you can display your logo on the map using an AdornmentLayer. The advantage of using an Adornment is that the graphic stays in place and doesn'​t move as you pan your map. The sample should work for various kinds of logos and allow you to change the position using the AdornmentLayer'​s properties.
-<div sampleitem>​
-====  Heat Map  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Heat Map.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_HeatMap_CS_091022.zip|View Source]]
-{{:​File:​DesktopEditionSample_HeatMap_CS_101210.zip|C#​ Download}}
-Heat maps is a technique increasingly used in various fields such in biology and other fields. See http://​en.wikipedia.org/​wiki/​Heat_map. They are also used for displaying areas of webs page most frequently scanned by users. http://​csscreme.com/​heat-maps/​.\\ ​  \\ At ThinkGeo, we are taking this concept to GIS and applying it to geographic maps. Heat maps are a great way to give the users a visually compelling representation of the distribution and intensity of geographic phenomenon. \\  \\ Today, we are posting two Desktop projects on that subject. The first one is using the swine flu data we used in an earlier project. You can see how powerful the visualization of that data is to show the spatial distribution flu swine cases. In the next project, you will see how to take into account column values to produce various degrees of intensity using some earthquake data. In those two projects, you will need references to MapSuiteCore.dll and  DesktopEdition.dll.
-<div sampleitem>​
-====  Highlight at Mouse Hover  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite WPF Desktop Edition Sample Highlight At Mouse Hover.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_HighlightAtMouseHover_CS_120131.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_HighlightAtMouseHover_CS_120131.zip|C#​ Download}}
-In this WPF project, we show you how to highlight a feature when the user hovers the mouse pointer over it. This effect can be realized in Map Suite by using a timer and doing some spatial querying based on the location of the mouse pointer. This sample works with area-based features but the same could be accomplished with point- or line-based features simply by using different spatial queries.
-<div sampleitem>​
-====  Heat Map with earthquakes ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Heat Map with earthquakes.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_HeatMapWithEarthquakes_CS_091022.zip|View Source]]
-{{:​File:​DesktopEditionSample_HeatMapWithEarthquakes_CS_101210.zip|C#​ Download}}
-After the project on displaying swine flu data using the heat map technique, here you learn how to apply parameters other than strictly spatial distribution to affect the coloring of the map.\\ ​  \\ In this example, the magnitude of each earthquake (from 0 to 12) is taken into account to influence the displaying of the heat map. The result is California appearing even more intense than if only the spatial distribution were taken into account.\\ ​ \\ As for the previous project, you will need references to MapSuiteCore.dll,​ DesktopEdition.dll. As a caveat on heat map in GIS, it is worth mentioning that while this is great tool for displaying data in a very appealing and communicative way, it cannot be used as an analysis tool for studying spatial behaviors. For spatial analysis, GRID is the appropriate tool. Although a heat map looks like a GRID, it is not one and it cannot substitute GRID for spatial analysis.
-<div sampleitem>​
-====  Image Stream Loading ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Image Stream Loading.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_ImageStreamLoading_CS_100701.zip|View Source]]
-{{:​File:​DesktopEditionSample_ImageStreamLoading_CS_100701.zip|C#​ Download}}
-<div sampleitem>​
-====  KML Extension ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample KML Extension.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_KmlExtension_CS_100623.zip|View Source]]
-{{:​File:​DesktopEditionSample_KmlExtension_CS_100623.zip|C#​ Download}}
-KML is the file format for displaying geographic data in a Google Earth browser such as Google Earth. Now, you can also display such a file on a Map Suite control. Thanks to its flexible architecture to extent to new file formats, in today’s project we wrote the logic for supporting KML. Look at the class KmlfeatureSource inheriting from FeatureSource to see how the logic for reading FML files was implemented. As well, you can see the class KmlStyle inheriting from Style for the drawing logic. And feel free to modify and improve those classes with your own implementations.
-<div sampleitem>​
-====  Latitude Longitude Graticule ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Latitude Longitude Graticule.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_LatLongGraticule_CS_090827.zip|View Source]]
-{{:​File:​DesktopEditionSample_LatLongGraticule_CS_090827.zip|C#​ Download}}
-After the projects on North Arrow and Compass, we created another project related to Adornment Layer to have a more stylish map and give more information to the user navigating the map.\\ ​  \\ In this project, we create a Graticule Adorment Layer that shows Meridians and Parallels displaying through the map. Meridians are lines of longitude and they have a North South orientation. Parallels are lines of latitude and they have an East West orientation. ​ \\ Showing graticule for latitude and longitude is a standard way in cartography to give spatial references to the users. \\  \\ You will find two zip files. One is for the Desktop Edition “LatLongGraticule” and it shows nicely the effect of the meridians and parallels as you pan and zoom in and out. You will also see, as additional spatial references to the users, the latitude and longitude location at the mouse pointer in labels at the mouse move event. You will see that information in the decimal degrees format and in the Degrees Minutes Seconds format.\\ ​ \\ For those that don’t have the Desktop Edition, you will find the zip file “LatLongGraticuleServices” for the Service edition. It is using exactly the same GraticuleAdormentLayer class.\\ ​ \\ In the future, we will offer another class for graticule with more options for formatting and displaying the graticule. It will also offer projection support for map that are not in Decimal Degrees map unit.
-<div sampleitem>​
-====  Native TAB File Suppport ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​TabFileSupport.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_NativeTabFileSupport_CS_110524.zip|View Source]]
-{{:​File:​DesktopEditionSample_NativeTabFileSupport_CS_110524.zip|C#​ Download}}
-One of the most exciting new features in MapSuite 5.0 is native TAB file support. ​ In the past, the FDO extension was used for displaying TAB files in MapSuite. ​ Now with the new TabFeatureLayer,​ we have a simpler and more stable method of working with TAB files. ​ \\  \\ This Code Community project demonstrates how to load and display a TAB file using the new TabFeatureLayer. ​ The example also allows you to add, edit and delete features from the TAB file.
-<div sampleitem>​
-====  Numbered Grid  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Numbered Grid.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_NumberedGrid_CS_100622.zip|View Source]]
-{{:​File:​DesktopEditionSample_NumberedGrid_CS_100622.zip|C#​ Download}}
-<div sampleitem>​
-====  PopupOverlay ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample PopupOverlay.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_PopupOverlay_101007.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_PopupOverlay_101007.zip|C#​ Download}}
-[[Map Suite Samples Applies To|Applies To: Wpf ]]
-In this Wpf project, we explore more capabilities of the PopupOverlay and its collection of Popups. With the Content property, we can add a TextBox or any other control to a Popup. For example, here we show how to have the column value of a selected feature appear in a Popup on the user MapClick event. Notice how that column value can be easily changed by typing in the TextBox of the Popup and committing the edit.
-<div sampleitem>​
-==== Save & Load State ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Save Load State.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_SaveLoadState_101019.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_SaveLoadState_101019.zip|C#​ Download}}
-The purpose of this Wpf project is to show how to use the new SaveState and LoadState of the SimpleMarkerOverlay. We show how you can simply drag the icons to change their location, save their state to a file and then reload the state from that file. For this sample to work, you will need to use the latest [[Map Suite Daily Builds Guide|production daily build]] of "​MapSuiteCore.dll"​ and "​WpfDesktopEdition.dll",​ version 4.0.40.87 or higher. This project applies to Map Suite Wpf Desktop Edition only.
-<div sampleitem>​
-====  Shapefile Encryption ​ ====
-<div screenshot>​
-{{:​No_screenshot.jpg?​300x180}}
-<div content>
-[[Source_Code_DesktopEditionSample_ShapefileEncryption_CS_100417.zip|View Source]]
-{{:​File:​DesktopEditionSample_ShapefileEncryption_CS_100417.zip|C#​ Download}}
-In today’s project, we are looking at a way to encrypt shapefiles to prevent them from being used outside the application. We show how to encrypt and decrypt shapefiles using streams. You will see that a very simple encryption algorithm is used but by looking at the example, you will be able to implement your own.\\ ​  \\ Disclaimer: This encryption system can be used only on small shapefiles due to the amount of memory used. A typical use would be to encrypt some valuable small shapefiles you don't want your users to access. In the future, Map Suite will provide a full encryption system as an API.
-<div sampleitem>​
-====  WMTS Overlay ​ ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample WmtsTiledOverlay.PNG?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_WmtsTiledOverlay_121116.zip|View Source]]
-{{:​File:​Source_Code_WpfDesktopEditionSample_WmtsTiledOverlay_121116.zip|C#​ Download}}
-This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward,​ while behind the scenes we request tiles from the server asynchronously and efficiently,​ and stitch them into a proper map. \\  This class is introduced from version 6.0.187.0, besides this WmtsOverlay,​ we also have WmtsLayer available. Here is the [[Map_Suite_Services_Edition_Layers_FeatureSources_Samples#​WMTS_Layer|WMTSLayer Sample]].
-<div sampleitem>​
-==== ENC Viewer for displaying S-57 (*.000) File  ====
-<div screenshot>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition S57Viewer.jpg?​300x180}}
-<div content>
-[[Source_Code_WpfDesktopEditionSample_S57Viewer.zip|View Source]]
-{{:​File:​WpfDesktopEditionSample_S57Viewer_150724.zip|C#​ Download}}
-Today’s project is a tool of ENC Viewer for displaying unencrypted Electronic Navigational Charts (ENCs) available in the S-57 exchange format (*.000). ​ \\ This tool takes use of Map Suite HydrographyExtension to display ENC data in compliance with the latest version of ECDIS Presentation Library Edition 4.0, which is defined by the International Hydrographic Organization (IHO) in the special publication S-52.  \\  \\ NOTE: the styling file "​NauticalCharts.xml"​ for drawing S-57 (*.000) file is included in the source code package.
-{{page>​Map Suite Services Edition Layers FeatureSources Samples}}
map_suite_wpf_desktop_edition_layers_featuresources_samples.1443153401.txt.gz · Last modified: 2015/09/25 03:56 by admin
