map_suite_silverlight_edition_labeling_samples
map_suite_silverlight_edition_labeling_samples [2015/09/08 10:42]
-====== Map Suite Silverlight Edition Labeling Samples ======
-==== Labeling based on size ====
-<div sampleitem>​
-{{silverlightedition:​codesamples:​Map Suite Silverlight Edition Sample Labeling based on size.jpg?​300x180}}
-[[Source_Code_DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|View Source]] |
-{{:​File:​DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== MultiLine Labeling ====
-<div sampleitem>​
-{{silverlightedition:​codesamples:​Map Suite Wpf Desktop Sample MultiLine Labeling.jpg?​300x180}}
-[[Source_Code_WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|View Source]] |
-{{:​File:​WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Multiple Labels ====
-<div sampleitem>​
-{{silverlightedition:​codesamples:​Picture Map Suite Samples Multiple Labels.png?​300x180}}
-[[Source_Code_DesktopEditionSample_MultipleLabels_CS_100128.zip|View Source]] |
-{{:​File:​DesktopEditionSample_MultipleLabels_CS_100128.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like "​[ColumnName1][ColumnName2]..."​ and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.\\ ​  \\ For more information you can see the discussion forum post below: ​ \\ http://​gis.thinkgeo.com/​Support/​DiscussionForums/​tabid/​143/​aff/​21/​aft/​6955/​afv/​topic/​Default.aspx ​ \\
-{{page>​map_suite_services_edition_labeling_samples}}
map_suite_silverlight_edition_labeling_samples.1441708944.txt.gz · Last modified: 2015/09/08 10:42 by admin
