thinkgeo.mapsuite.webedition.mousecoordinatetype
thinkgeo.mapsuite.webedition.mousecoordinatetype [2015/09/18 03:08]
-====== ThinkGeo.MapSuite.WebEdition.MouseCoordinateType ======
-This enumeration determines the MousePostion Type that appears when the pointer is moving on the map.
-== Remarks ==
-The Map.MousePosition.MousePostionType property uses this enumeration to determine which position type appears when the pointer is moving around the map.
-== Items ==
-**LongitudeLatitude**
-  * **Summary**:​Default mouse position type. Format: "​longitude,​ latitude"​.
-**LatitudeLongitude**
-  * **Summary**:​Default mouse position type. Format: "​latitude,​ longitude"​.
-**DegreesMinutesSeconds**
-  * **Summary**:​Appears as degrees, minutes, seconds. Format: "​Degressº Minutes''​ Seconds'"​.
-**DegreesMinutesSecondsLatitudeLongitude**
thinkgeo.mapsuite.webedition.mousecoordinatetype.1442545733.txt.gz · Last modified: 2015/09/18 03:08 by admin
