thinkgeo.mapsuite.webedition.measuremaptool [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.WebEdition.MeasureMapTool ====== | ||
| - | <!-- Class --> | ||
| - | Represents the measure map tool which allows measurements for features. | ||
| - | === Remarks === | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool</a> | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.WebEdition.MapTool]] | ||
| - | ***[[ThinkGeo.MapSuite.WebEdition.MeasureMapTool]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MeasureMapTool()|MeasureMapTool]] | | | Initialize an instance of the MeasureMapTool class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | [[ThinkGeo.MapSuite.WebEdition.MapTool|MapTool]] | Returns a JSON string that represents the map control object. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Enabled|Enabled]] | Boolean | [[ThinkGeo.MapSuite.WebEdition.MapTool|MapTool]] | Gets or sets a value that turns the feature on and off. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Geodesic|Geodesic]] | Boolean | | Indicate whether to measure geodesic distance. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MeasureType|MeasureType]] | [[ThinkGeo.MapSuite.WebEdition.MeasureType|MeasureType]] | | Represents the different types of the MeasureMapTool. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MeasureUnitType|MeasureUnitType]] | [[ThinkGeo.MapSuite.WebEdition.MeasureUnitType|MeasureUnitType]] | | Represents the display system units for output measurements. | | ||
| - | ==== MeasureMapTool() ==== | ||
| - | Initialize an instance of the MeasureMapTool class. | ||
| - | The default MeasureType is Line, and the display system units is Metric by default, also it measures geodesic distance by default. | ||
| - | === Parameters === | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Equals.28Object.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Equals.28Object.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#GetHashCode.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#GetHashCode.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#GetType.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#GetType.28.29</a> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string that represents the map control object. | ||
| - | This method returns a JSON string that instructs the client Javascript to create a specific client object. | ||
| - | | String<!-- System.String --> | A JSON string that represents the map control. | | ||
| - | <!-- ThinkGeo.MapSuite.WebEdition.MapTool --> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#ToString.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#ToString.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Finalize.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Finalize.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MemberwiseClone.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MemberwiseClone.28.29</a> | ||
| - | ==== Enabled ==== | ||
| - | Gets or sets a value that turns the feature on and off. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Enabled" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Enabled</a> | ||
| - | ^ Return Type ^ | ||
| - | ==== Geodesic ==== | ||
| - | Indicate whether to measure geodesic distance. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Geodesic" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#Geodesic</a> | ||
| - | <!-- ThinkGeo.MapSuite.WebEdition.MeasureMapTool --> | ||
| - | ==== MeasureType ==== | ||
| - | Represents the different types of the MeasureMapTool. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MeasureType" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MeasureType</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.MeasureType|MeasureType]]<!-- ThinkGeo.MapSuite.WebEdition.MeasureType --> | | ||
| - | ==== MeasureUnitType ==== | ||
| - | Represents the display system units for output measurements. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MeasureUnitType" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MeasureMapTool#MeasureUnitType</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.MeasureUnitType|MeasureUnitType]]<!-- ThinkGeo.MapSuite.WebEdition.MeasureUnitType --> | | ||
| - | __NOTOC__ | ||
| - | [[Category:WebEdition]] | ||
| - | [[Category:ThinkGeo.MapSuite.WebEdition]] | ||
