thinkgeo.mapsuite.webedition.markervalueitem [2015/09/18 03:08] admin |
| - | ====== ThinkGeo.MapSuite.WebEdition.MarkerValueItem ====== | ||
| - | This class represents one value in a ValueMarkerStyle. | ||
| - | *System.Object | ||
| - | ***ThinkGeo.MapSuite.WebEdition.MarkerValueItem** | ||
| - | ** {{wiki:PublicMethod.gif|}} MarkerValueItem() ** | ||
| - | Initialize a new instance of the MarkerValueItem class. | ||
| - | == Remarks == | ||
| - | N/A | ||
| - | == Parameters == | ||
| - | ** {{wiki:PublicMethod.gif|}} MarkerValueItem(String) ** | ||
| - | Initialize a new instance of the MarkerValueItem class using the value string specified. | ||
| - | N/A | ||
| - | * //value// | ||
| - | * Type:String | ||
| - | * Description:The string to compare with the column value of features, which determines whether or not to use this value item to create the markers. | ||
| - | ** {{wiki:PublicMethod.gif|}} MarkerValueItem(String,MarkerStyle) ** | ||
| - | Initialize a new instance of the MarkerValueItem class with the value string and custom marker style specified. | ||
| - | It is recommended that you do not use this constructor if it is not necessary. Instead, you can set the properties directly on the DefaultMarkerStyle. | ||
| - | * //customMarkerStyle// | ||
| - | * Type:[[ThinkGeo.MapSuite.WebEdition.MarkerStyle|MarkerStyle]] | ||
| - | * Description:The marker style that is applied to the markers with higher priority. | ||
| - | N/A | ||
| - | N/A | ||
| - | == Return Value == | ||
| - | * Description:N/A | ||
| - | N/A | ||
| - | N/A | ||
| - | * Type:Boolean | ||
| - | * //obj// | ||
| - | * Type:Object | ||
| - | N/A | ||
| - | N/A | ||
| - | * Type:Int32 | ||
| - | N/A | ||
| - | N/A | ||
| - | * Type:Type | ||
| - | N/A | ||
| - | N/A | ||
| - | * Type:Void | ||
| - | N/A | ||
| - | N/A | ||
| - | ** {{wiki:PublicProperty.gif|}} Value ** | ||
| - | Gets or sets the value that we will use to match with the feature data. If the value matches, we will use the style for this item. | ||
| - | N/A | ||
| - | ** {{wiki:PublicProperty.gif|}} DefaultMarkerStyle ** | ||
| - | Gets or sets the marker style that will be applied to the markers if the CustomMarkerStyle is not defined. | ||
| - | N/A | ||
| - | * Type:[[ThinkGeo.MapSuite.WebEdition.PointMarkerStyle|PointMarkerStyle]] | ||
| - | ** {{wiki:PublicProperty.gif|}} CustomMarkerStyle ** | ||
| - | Gets or sets the style that could be any type of MarkerStyle. | ||
| - | The CustomMarkerStyle could be any type of MarkerStyle. This style has a higher priority than the DefaultMarkerStyle. This means that if you defined both DefaultMarkerStyle and CustomMarkerStyle, the CustomMarkerStyle will be used. | ||
