thinkgeo.mapsuite.webedition.maptools [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.WebEdition.MapTools ====== | ||
| - | <!-- Class --> | ||
| - | Contains the different map tools as properties and acts as an entrance for setting these map controls. | ||
| - | === Remarks === | ||
| - | This class is designed to be easy to use. It contains all the available tools of the map. You can find and set those map tools easily by using this class. | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.WebEdition.MapTools]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MapTools()|MapTools]] | | | Initialize an instance of the MapTools class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | | Returns a JSON string that contains all of the map tools settings. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#AnimationPanMapTool|AnimationPanMapTool]] | [[ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool|AnimationPanMapTool]] | | Gets an AnimationPanMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#KeyboardMapTool|KeyboardMapTool]] | [[ThinkGeo.MapSuite.WebEdition.KeyboardMapTool|KeyboardMapTool]] | | Gets a KeyboardMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#LoadingImage|LoadingImage]] | [[ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool|LoadingImageMapTool]] | | Gets a LoadingImageMapTool object for setting | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Logo|Logo]] | [[ThinkGeo.MapSuite.WebEdition.LogoMapTool|LogoMapTool]] | | Gets a LogoMapTool object for setting | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MeasureMapTool|MeasureMapTool]] | [[ThinkGeo.MapSuite.WebEdition.MeasureMapTool|MeasureMapTool]] | | Gets an MeasureMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MiniMap|MiniMap]] | [[ThinkGeo.MapSuite.WebEdition.MiniMapMapTool|MiniMapMapTool]] | | Gets a MiniMapMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MouseCoordinate|MouseCoordinate]] | [[ThinkGeo.MapSuite.WebEdition.MouseCoordinateMapTool|MouseCoordinateMapTool]] | | Gets a MouseCoordinateMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MouseMapTool|MouseMapTool]] | [[ThinkGeo.MapSuite.WebEdition.MouseMapTool|MouseMapTool]] | | Gets a MouseMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#OverlaySwitcher|OverlaySwitcher]] | [[ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool|OverlaySwitcherMapTool]] | | Gets an OverlaySwitcherMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#PanZoom|PanZoom]] | [[ThinkGeo.MapSuite.WebEdition.PanZoomMapTool|PanZoomMapTool]] | | Gets a PanZoomMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#PanZoomBar|PanZoomBar]] | [[ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool|PanZoomBarMapTool]] | | Gets a PanZoomBarMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#ScaleLine|ScaleLine]] | [[ThinkGeo.MapSuite.WebEdition.ScaleLineMapTool|ScaleLineMapTool]] | | Gets a ScaleLineMapTool object for setting. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TouchMapTool|TouchMapTool]] | [[ThinkGeo.MapSuite.WebEdition.TouchMapTool|TouchMapTool]] | | | | ||
| - | ==== MapTools() ==== | ||
| - | Initialize an instance of the MapTools class. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MapTools.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MapTools.28.29</a> | ||
| - | === Parameters === | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Equals.28Object.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Equals.28Object.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetHashCode.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetHashCode.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetType.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#GetType.28.29</a> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string that contains all of the map tools settings. | ||
| - | This method is used to generate the JSON string for all of the map controls. The JSON string will be sent to the client side to create corresponding client-side map controls. | ||
| - | | String<!-- System.String --> | A JSON string that represents the settings for all of the map tools. | | ||
| - | <!-- ThinkGeo.MapSuite.WebEdition.MapTools --> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ToString.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ToString.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Finalize.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Finalize.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MemberwiseClone.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MemberwiseClone.28.29</a> | ||
| - | ==== AnimationPanMapTool ==== | ||
| - | Gets an AnimationPanMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#AnimationPanMapTool" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#AnimationPanMapTool</a> | ||
| - | ^ Return Type ^ | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool|AnimationPanMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool --> | | ||
| - | ==== KeyboardMapTool ==== | ||
| - | Gets a KeyboardMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#KeyboardMapTool" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#KeyboardMapTool</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.KeyboardMapTool|KeyboardMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.KeyboardMapTool --> | | ||
| - | ==== LoadingImage ==== | ||
| - | Gets a LoadingImageMapTool object for setting | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#LoadingImage" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#LoadingImage</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool|LoadingImageMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool --> | | ||
| - | ==== Logo ==== | ||
| - | Gets a LogoMapTool object for setting | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Logo" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#Logo</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.LogoMapTool|LogoMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.LogoMapTool --> | | ||
| - | ==== MeasureMapTool ==== | ||
| - | Gets an MeasureMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MeasureMapTool" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MeasureMapTool</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.MeasureMapTool|MeasureMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.MeasureMapTool --> | | ||
| - | ==== MiniMap ==== | ||
| - | Gets a MiniMapMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MiniMap" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MiniMap</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.MiniMapMapTool|MiniMapMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.MiniMapMapTool --> | | ||
| - | ==== MouseCoordinate ==== | ||
| - | Gets a MouseCoordinateMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseCoordinate" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseCoordinate</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.MouseCoordinateMapTool|MouseCoordinateMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.MouseCoordinateMapTool --> | | ||
| - | ==== MouseMapTool ==== | ||
| - | Gets a MouseMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseMapTool" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#MouseMapTool</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.MouseMapTool|MouseMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.MouseMapTool --> | | ||
| - | ==== OverlaySwitcher ==== | ||
| - | Gets an OverlaySwitcherMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#OverlaySwitcher" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#OverlaySwitcher</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool|OverlaySwitcherMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool --> | | ||
| - | ==== PanZoom ==== | ||
| - | Gets a PanZoomMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoom" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoom</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.PanZoomMapTool|PanZoomMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.PanZoomMapTool --> | | ||
| - | ==== PanZoomBar ==== | ||
| - | Gets a PanZoomBarMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoomBar" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#PanZoomBar</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool|PanZoomBarMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool --> | | ||
| - | ==== ScaleLine ==== | ||
| - | Gets a ScaleLineMapTool object for setting. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ScaleLine" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#ScaleLine</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.ScaleLineMapTool|ScaleLineMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.ScaleLineMapTool --> | | ||
| - | ==== TouchMapTool ==== | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#TouchMapTool" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.MapTools#TouchMapTool</a> | ||
| - | | [[ThinkGeo.MapSuite.WebEdition.TouchMapTool|TouchMapTool]]<!-- ThinkGeo.MapSuite.WebEdition.TouchMapTool --> | | ||
| - | __NOTOC__ | ||
| - | [[Category:WebEdition]] | ||
| - | [[Category:ThinkGeo.MapSuite.WebEdition]] | ||
