thinkgeo.mapsuite.webedition.maptool
thinkgeo.mapsuite.webedition.maptool [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.WebEdition.MapTool ======
-<!-- Class -->
-Defines the properties and methods that are shared by all controls on the map.
-=== Remarks ===
-This is the base class that all of the map controls are derived from.
-*System.Object
-**[[ThinkGeo.MapSuite.WebEdition.MapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.KeyboardMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.LoadingImageMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.LogoMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.MeasureMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.MiniMapMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.MouseCoordinateMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.MouseMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.OverlaySwitcherMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.PanZoomBarMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.PanZoomMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.ScaleLineMapTool]]
-***[[ThinkGeo.MapSuite.WebEdition.TouchMapTool]]
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​MapTool()|MapTool]] ​  ​| ​   |    | Initialize an instance of the MapTool class. ​  |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​MapTool(Boolean)|MapTool]] ​  | Boolean ​  ​| ​   | Initialize an instance of the MapTool class with a boolean value that indicates whether it is enabled. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ToJson()|ToJson]] ​  ​| ​   |    | Returns a JSON string that represents the map control object. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Enabled|Enabled]] ​  | Boolean ​  ​| ​   | Gets or sets a value that turns the feature on and off.   |
-==== MapTool() ====
-Initialize an instance of the MapTool class.
-=== Overloads ===
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​MapTool.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​MapTool.28.29</​a>​
-=== Parameters ===
-[[#​Protected Constructors|Go Back]]
-==== MapTool(Boolean) ====
-Initialize an instance of the MapTool class with a boolean value that indicates whether it is enabled.
-=== Overloads ===
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​MapTool.28Boolean.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​MapTool.28Boolean.29</​a>​
-=== Parameters ===
-| enabled ​  | Boolean<​!-- System.Boolean --> ​  | A boolean value that indicates whether this MapTool is enabled. ​  |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​Equals.28Object.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​Equals.28Object.29</​a>​
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​GetHashCode.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​GetHashCode.28.29</​a>​
-=== Parameters ===
-==== GetType() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​GetType.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​GetType.28.29</​a>​
-=== Parameters ===
-==== ToJson() ====
-Returns a JSON string that represents the map control object.
-=== Remarks ===
-This method returns a JSON string that instructs the client Javascript to create a specific client object.
-| String<​!-- System.String --> ​  | A JSON string that represents the map control. ​  |
-=== Parameters ===
-<!-- ThinkGeo.MapSuite.WebEdition.MapTool -->
-==== ToString() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​ToString.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​ToString.28.29</​a>​
-=== Parameters ===
-==== Finalize() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​Finalize.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​Finalize.28.29</​a>​
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​MemberwiseClone.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​MemberwiseClone.28.29</​a>​
-=== Parameters ===
-==== Enabled ====
-Gets or sets a value that turns the feature on and off.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​Enabled"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.MapTool#​Enabled</​a>​
-^ Return Type ^
-===== Public Events =====
-__NOTOC__
-[[Category:​WebEdition]]
-[[Category:​ThinkGeo.MapSuite.WebEdition]]
thinkgeo.mapsuite.webedition.maptool.1440040135.txt.gz ยท Last modified: 2015/09/18 03:08 (external edit)
