thinkgeo.mapsuite.webedition.georesourcefactory
thinkgeo.mapsuite.webedition.georesourcefactory [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.WebEdition.GeoResourceFactory ======
-<!-- Class -->
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory</​a>​
-*System.Object
-**[[ThinkGeo.MapSuite.WebEdition.GeoResourceFactory]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​GeoResourceFactory()|GeoResourceFactory]] ​  ​| ​   |    |    |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​GetHandler(HttpContext,​ String, String, String)|GetHandler]] ​  | HttpContext,​ String, String, String ​  ​| ​   | Returns an instance of a class that implements the System.Web.IHttpHandler interface. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ReleaseHandler(IHttpHandler)|ReleaseHandler]] ​  | IHttpHandler ​  ​| ​   | Enables a factory to reuse an existing handler instance. ​  |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​GetHandlerCore(HttpContext)|GetHandlerCore]] ​  | HttpContext ​  ​| ​   | Returns an instance of a class that implements the System.Web.IHttpHandler interface. ​  |
-==== GeoResourceFactory() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GeoResourceFactory.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GeoResourceFactory.28.29</​a>​
-=== Parameters ===
-===== Public Methods =====
-==== Equals(Object) ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​Equals.28Object.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​Equals.28Object.29</​a>​
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHandler(HttpContext,​ String, String, String) ====
-Returns an instance of a class that implements the System.Web.IHttpHandler interface.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetHandler.28HttpContext.2C_String.2C_String.2C_String.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetHandler.28HttpContext.2C_String.2C_String.2C_String.29</​a>​
-| IHttpHandler<​!-- System.Web.IHttpHandler --> ​  | A new System.Web.IHttpHandler object that processes the request. ​  |
-=== Parameters ===
-| context ​  | HttpContext<​!-- System.Web.HttpContext --> ​  | An instance of the System.Web.HttpContext class that provides references to intrinsic server objects (for example, Request, Response, Session, and Server) used to service HTTP requests. ​  |
-| requestType ​  | String<​!-- System.String --> ​  | The HTTP data transfer method (GET or POST) that the client uses.   |
-| url   | String<​!-- System.String --> ​  | The System.Web.HttpRequest.RawUrl of the requested resource. ​  |
-| pathTranslated ​  | String<​!-- System.String --> ​  | The System.Web.HttpRequest.PhysicalApplicationPath to the requested resource. ​  |
-<!-- ThinkGeo.MapSuite.WebEdition.GeoResourceFactory -->
-==== GetHashCode() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetHashCode.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetHashCode.28.29</​a>​
-=== Parameters ===
-==== GetType() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetType.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetType.28.29</​a>​
-=== Parameters ===
-==== ReleaseHandler(IHttpHandler) ====
-Enables a factory to reuse an existing handler instance.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​ReleaseHandler.28IHttpHandler.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​ReleaseHandler.28IHttpHandler.29</​a>​
-=== Parameters ===
-| handler ​  | IHttpHandler<​!-- System.Web.IHttpHandler --> ​  | The System.Web.IHttpHandler object to reuse. ​  |
-==== ToString() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​ToString.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​ToString.28.29</​a>​
-=== Parameters ===
-==== Finalize() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​Finalize.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​Finalize.28.29</​a>​
-=== Parameters ===
-==== GetHandlerCore(HttpContext) ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetHandlerCore.28HttpContext.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​GetHandlerCore.28HttpContext.29</​a>​
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​MemberwiseClone.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.GeoResourceFactory#​MemberwiseClone.28.29</​a>​
-=== Parameters ===
-===== Public Events =====
-__NOTOC__
-[[Category:​WebEdition]]
-[[Category:​ThinkGeo.MapSuite.WebEdition]]
thinkgeo.mapsuite.webedition.georesourcefactory.1440040135.txt.gz ยท Last modified: 2015/09/18 03:07 (external edit)
