thinkgeo.mapsuite.webedition.editsettings
thinkgeo.mapsuite.webedition.editsettings [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.WebEdition.EditSettings ======
-<!-- Class -->
-Provides editing options when the EditOverlay is in EditShape mode.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings</​a>​
-*System.Object
-**[[ThinkGeo.MapSuite.WebEdition.EditSettings]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​EditSettings()|EditSettings]] ​  ​| ​   |    | Initialize an instance of the EditSetting class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ToJson()|ToJson]] ​  ​| ​   |    | Returns a JSON string that contains the information for setting the edit mode at client side.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsDraggable|IsDraggable]] ​  | Boolean ​  ​| ​   | Gets a value that indicates whether the shape can be dragged. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsReshapable|IsReshapable]] ​  | Boolean ​  ​| ​   | Gets a value that indicates whether the shape can be reshaped. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsResizable|IsResizable]] ​  | Boolean ​  ​| ​   | Gets a value that indicates whether the shape can be resized. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsRotatable|IsRotatable]] ​  | Boolean ​  ​| ​   | Gets a value that indicates whether the shape can be rotated. ​  |
-==== EditSettings() ====
-Initialize an instance of the EditSetting class.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​EditSettings.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​EditSettings.28.29</​a>​
-=== Parameters ===
-===== Public Methods =====
-==== Equals(Object) ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​Equals.28Object.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​Equals.28Object.29</​a>​
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​GetHashCode.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​GetHashCode.28.29</​a>​
-=== Parameters ===
-==== GetType() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​GetType.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​GetType.28.29</​a>​
-=== Parameters ===
-==== ToJson() ====
-Returns a JSON string that contains the information for setting the edit mode at client side.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​ToJson.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​ToJson.28.29</​a>​
-| String<​!-- System.String --> ​  | A JSON string that is used to set the edit mode at client side.   |
-=== Parameters ===
-<!-- ThinkGeo.MapSuite.WebEdition.EditSettings -->
-==== ToString() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​ToString.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​ToString.28.29</​a>​
-=== Parameters ===
-==== Finalize() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​Finalize.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​Finalize.28.29</​a>​
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​MemberwiseClone.28.29"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​MemberwiseClone.28.29</​a>​
-=== Parameters ===
-==== IsDraggable ====
-Gets a value that indicates whether the shape can be dragged.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsDraggable"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsDraggable</​a>​
-^ Return Type ^
-==== IsReshapable ====
-Gets a value that indicates whether the shape can be reshaped.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsReshapable"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsReshapable</​a>​
-^ Return Type ^
-==== IsResizable ====
-Gets a value that indicates whether the shape can be resized.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsResizable"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsResizable</​a>​
-^ Return Type ^
-==== IsRotatable ====
-Gets a value that indicates whether the shape can be rotated.
-=== Remarks ===
-For the most updated Info for this topic, please check it here:<a href="​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsRotatable"​ target="​_blank">​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.EditSettings#​IsRotatable</​a>​
-^ Return Type ^
-===== Public Events =====
-__NOTOC__
-[[Category:​WebEdition]]
-[[Category:​ThinkGeo.MapSuite.WebEdition]]
thinkgeo.mapsuite.webedition.editsettings.1440040135.txt.gz ยท Last modified: 2015/09/18 03:07 (external edit)
