thinkgeo.mapsuite.webedition.arcgisserverrestoverlay
thinkgeo.mapsuite.webedition.arcgisserverrestoverlay [2015/09/22 08:48]
-====== ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay ======
-This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://​sampleserver1.arcgisonline.com/​ArcGIS/​SDK/​REST/​index.html ;​specifically,​ the URL provided to this layer should be an export service URL: http://​sampleserver1.arcgisonline.com/​ArcGIS/​SDK/​REST/​export.html
-  *System.Object
-    *ThinkGeo.MapSuite.WebEdition.Overlay
-      ***ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay**
-** {{wiki:​PublicMethod.gif|}} ArcGISServerRestOverlay() **
-  * //​Initialize an instance of the ArcGISServerRestOverlay class with none parameter.//​
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ArcGISServerRestOverlay.28.29//​
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} ArcGISServerRestOverlay(String) **
-  * //​Initialize an instance of the ArcGISServerRestOverlay class.//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ArcGISServerRestOverlay.28String.29//​
-== Parameters ==
-  * //id//
-    * Type:String
-    * Description:​The identifier string of the ArcGISServerRestOverlay.
-** {{wiki:​PublicMethod.gif|}} ArcGISServerRestOverlay(String,​Uri) **
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ArcGISServerRestOverlay.28String.2C_Uri.29//​
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​serverUri//​
-    * Type:Uri
-    * Description:​The uri of the ArcGIS REST SERVER
-** {{wiki:​PublicMethod.gif|}} ArcGISServerRestOverlay(String,​Uri,​TileType) **
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ArcGISServerRestOverlay.28String.2C_Uri.2C_TileType.29//​
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​serverUri//​
-    * Type:Uri
-  * //​tileType//​
-    * Type:​[[ThinkGeo.MapSuite.WebEdition.TileType|TileType]]
-    * Description:​The Tile Type of the layer
-** {{wiki:​PublicMethod.gif|}} ToJson() **
-  * //Returns a JSON string which contains the information for creating an overlay at the client side.//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ToJson.28.29//​
-== Return Value ==
-  * Type:String
-  * Description:​A JSON string which is used to create an overlay at the client side.
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ToString.28.29//​
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Equals.28Object.29//​
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​GetHashCode.28.29//​
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​GetType.28.29//​
-== Return Value ==
-  * Type:Type
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} 3xM=(Page) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //page//
-    * Type:Page
-** {{wiki:​ProtectedMethod.gif|}} RegisterJavaScriptLibraryCore(Page) **
-  * //Registers a Javascript library URL string to the client HTML page.//
-== Remarks ==
-  * //The <​strong>​RegisterJavaScriptLibraryCore</​strong>​ method allows derived classes to override and register their own Javascript library URL to the HTML page.//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //page//
-    * Type:Page
-    * Description:​The page object that is used for registering the javascript library.
-** {{wiki:​ProtectedMethod.gif|}} RaiseTickEvent(EventArgs) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​EventArgs
-** {{wiki:​ProtectedMethod.gif|}} OnTick(EventArgs) **
-  * //Raises the Tick event of the MarkerOverlay.//​
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​OnTick.28EventArgs.29//​
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​EventArgs
-    * Description:​An System.EventArgs object that contains the event data.
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Finalize.28.29//​
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​MemberwiseClone.28.29//​
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} Parameters **
-Gets a dictionary whose items will be passed to the ArcGIS REST Server server as parameters.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Parameters
-== Return Value ==
-  * Type:​Dictionary<​String,​String>​
-** {{wiki:​PublicProperty.gif|}} Projection **
-Gets or sets a string that will be sent to the ArcGIS REST server to get the images in the specific projection.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Projection
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} TileWidth **
-Gets or sets the width of each tile, if the WmsOverlay uses tiling.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​TileWidth
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} TileHeight **
-Gets or sets the height of each tile, if the WmsOverlay uses tiling.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​TileHeight
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} TransitionEffect **
-Gets or sets the transition effect to use when the map is zoomed.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​TransitionEffect
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.WebEdition.TransitionEffect|TransitionEffect]]
-** {{wiki:​PublicProperty.gif|}} TransitionEffectDelayInMilliseconds **
-N/A
-== Remarks ==
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} TileType **
-Gets or sets whether or not the ArcGISServerRestOverlay uses tiling.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ArcGISServerRestOverlay.28String.2C_Uri.2C_TileType.29
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} ServerUri **
-Gets or sets the URI that specifies the locations of the ArcGIS Rest servers.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​ServerUri
-== Return Value ==
-  * Type:Uri
-** {{wiki:​PublicProperty.gif|}} IsVisible **
-Gets or sets a value that indicates whether the overlay is visible on the map.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​IsVisible
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Name **
-Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Name
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Opacity **
-Gets or sets the opacity level of the overlay.
-== Remarks ==
-The <​strong>​Opacity</​strong>​ property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
-== Return Value ==
-  * Type:Single
-** {{wiki:​PublicProperty.gif|}} IsVisibleInOverlaySwitcher **
-Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​IsVisibleInOverlaySwitcher
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} IsBaseOverlay **
-Gets or sets a value that indicates whether the overlay is a base overlay.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​IsBaseOverlay
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Id **
-Gets the identifier for the overlay to be found.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Id
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} AutoRefreshInterval **
-Gets or sets the time interval in which the MarkerOverlay refreshes itself.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​AutoRefreshInterval
-== Return Value ==
-  * Type:​TimeSpan
-** {{wiki:​PublicProperty.gif|}} Attribution **
-N/A
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​Attribution
-== Return Value ==
-  * Type:String
-** {{wiki:​ProtectedProperty.gif|}} OverlayType **
-Gets a string that indicates the overlay type.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​OverlayType
-== Return Value ==
-  * Type:String
-** {{wiki:​ProtectedProperty.gif|}} HasTickEvent **
-Don't support auto tick event by default.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​HasTickEvent
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​ProtectedProperty.gif|}} 3hM= **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicEvent.gif|}} Tick **
-Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.ArcGISServerRestOverlay#​OnTick.28EventArgs.29
-Event Arguments:​EventArgs
thinkgeo.mapsuite.webedition.arcgisserverrestoverlay.1442911680.txt.gz ยท Last modified: 2015/09/22 08:48 by admin
