thinkgeo.mapsuite.webedition.animationpanmaptool
thinkgeo.mapsuite.webedition.animationpanmaptool [2015/09/22 08:47]
-====== ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool ======
-Represents an animation pan tool which allows map pans to the position which users click using the transition effect.
-  *System.Object
-    *ThinkGeo.MapSuite.WebEdition.MapTool
-      ***ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool**
-** {{wiki:​PublicMethod.gif|}} AnimationPanMapTool() **
-  * //​Initialize an instance of the AnimationPanMapTool class.//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​AnimationPanMapTool.28.29//​
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} ToJson() **
-  * //Returns a JSON string that represents the map control object.//
-== Remarks ==
-  * //This method returns a JSON string that instructs the client Javascript to create a specific client object.//
-== Return Value ==
-  * Type:String
-  * Description:​A JSON string that represents the map control.
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​ToString.28.29//​
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​Equals.28Object.29//​
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​GetHashCode.28.29//​
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​GetType.28.29//​
-== Return Value ==
-  * Type:Type
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​Finalize.28.29//​
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //For the most updated Info for this topic, please check it here:​http:​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​MemberwiseClone.28.29//​
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} Delay **
-The number of milliseconds between clicks before the event is considered a double-click.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​Delay
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} OnClientClick **
-Gets or sets the client-side script that executes when you click on the map using this Animation Pan map tool.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​OnClientClick
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Enabled **
-Gets or sets a value that turns the feature on and off.
-== Remarks ==
-For the most updated Info for this topic, please check it here:​http://​wiki.thinkgeo.com/​wiki/​ThinkGeo.MapSuite.WebEdition.AnimationPanMapTool#​Enabled
-== Return Value ==
-  * Type:​Boolean
thinkgeo.mapsuite.webedition.animationpanmaptool.1442911678.txt.gz ยท Last modified: 2015/09/22 08:47 by admin
