thinkgeo.mapsuite.silverlightedition.vertexremovingeditinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.vertexremovingeditinteractiveoverlayeventargs [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.SilverlightEdition.VertexRemovingEditInteractiveOverlayEventArgs ======
-<!-- Class -->
-Provides data for the VertexRemoving. event.
-*System.Object
-**System.EventArgs
-***[[ThinkGeo.MapSuite.SilverlightEdition.VertexRemovingEditInteractiveOverlayEventArgs]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​VertexRemovingEditInteractiveOverlayEventArgs()|VertexRemovingEditInteractiveOverlayEventArgs]] ​  ​| ​   |    | This is the default constructor of this parameter. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​VertexRemovingEditInteractiveOverlayEventArgs(Boolean,​ Feature, Vertex)|VertexRemovingEditInteractiveOverlayEventArgs]] ​  | Boolean, [[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]],​ [[ThinkGeo.MapSuite.SilverlightCore.Vertex|Vertex]] ​  ​| ​   | This is the commonly used constructor. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​AffectedVertexFeature|AffectedVertexFeature]] ​  | [[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]] ​  ​| ​   | This property gets or sets the Feature to be used to remove vertex. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Cancel|Cancel]] ​  | Boolean ​  ​| ​   | This property gets or sets the action to be canceled or not.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​RemovingVertex|RemovingVertex]] ​  | [[ThinkGeo.MapSuite.SilverlightCore.Vertex|Vertex]] ​  ​| ​   | This property gets or sets the vertex to be removed. ​  |
-==== VertexRemovingEditInteractiveOverlayEventArgs() ====
-=== Remarks ===
-=== Parameters ===
-==== VertexRemovingEditInteractiveOverlayEventArgs(Boolean,​ Feature, Vertex) ====
-=== Parameters ===
-| cancel ​  | Boolean<​!-- System.Boolean --> ​  | This parameter specified the cancel property. ​  |
-| affectedVertexFeature ​  | [[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]]<​!-- ThinkGeo.MapSuite.SilverlightCore.Feature --> ​  | This parameter specified the affectedVertex feature property. ​  |
-| removingVertex ​  | [[ThinkGeo.MapSuite.SilverlightCore.Vertex|Vertex]]<​!-- ThinkGeo.MapSuite.SilverlightCore.Vertex --> ​  | This parameter specified the target vertex to be removed. ​  |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== AffectedVertexFeature ====
-This property gets or sets the Feature to be used to remove vertex.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]]<​!-- ThinkGeo.MapSuite.SilverlightCore.Feature --> ​  |
-<!-- ThinkGeo.MapSuite.SilverlightEdition.VertexRemovingEditInteractiveOverlayEventArgs -->
-==== Cancel ====
-This property gets or sets the action to be canceled or not.
-^ Return Type ^
-==== RemovingVertex ====
-This property gets or sets the vertex to be removed.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.SilverlightCore.Vertex|Vertex]]<​!-- ThinkGeo.MapSuite.SilverlightCore.Vertex --> ​  |
-===== Public Events =====
-__NOTOC__
-[[Category:​SilverlightEdition]]
-[[Category:​ThinkGeo.MapSuite.SilverlightEdition]]
thinkgeo.mapsuite.silverlightedition.vertexremovingeditinteractiveoverlayeventargs.1440040135.txt.gz ยท Last modified: 2015/09/21 03:30 (external edit)
