thinkgeo.mapsuite.silverlightedition.vertexremovededitinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.vertexremovededitinteractiveoverlayeventargs [2015/09/21 03:30]
-====== ThinkGeo.MapSuite.SilverlightEdition.VertexRemovedEditInteractiveOverlayEventArgs ======
-Provides data for the VertexRemoved. event.
-  *System.Object
-    *System.EventArgs
-      ***ThinkGeo.MapSuite.SilverlightEdition.VertexRemovedEditInteractiveOverlayEventArgs**
-** {{wiki:​PublicMethod.gif|}} VertexRemovedEditInteractiveOverlayEventArgs() **
-== Remarks ==
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} VertexRemovedEditInteractiveOverlayEventArgs(Feature,​Vertex) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​affectedVertexFeature//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]]
-    * Description:​This parameter specified the affectedVertex feature property.
-  * //​removedVertex//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.Vertex|Vertex]]
-    * Description:​This parameter specified the target vertex removed.
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} AffectedVertexFeature **
-This property gets or sets the Feature to be used to remove vertex.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} RemovedVertex **
-This property gets or sets the vertex removed.
-== Remarks ==
-N/A
-== Return Value ==
thinkgeo.mapsuite.silverlightedition.vertexremovededitinteractiveoverlayeventargs.1442806204.txt.gz ยท Last modified: 2015/09/21 03:30 by admin
