thinkgeo.mapsuite.silverlightedition.trackendingtrackinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.trackendingtrackinteractiveoverlayeventargs [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.SilverlightEdition.TrackEndingTrackInteractiveOverlayEventArgs ======
-<!-- Class -->
-Provides data for the TrackEnding. event.
-*System.Object
-**System.EventArgs
-***[[ThinkGeo.MapSuite.SilverlightEdition.TrackEndingTrackInteractiveOverlayEventArgs]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​TrackEndingTrackInteractiveOverlayEventArgs()|TrackEndingTrackInteractiveOverlayEventArgs]] ​  ​| ​   |    | This is the default constructor of this parameter. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​TrackEndingTrackInteractiveOverlayEventArgs(BaseShape,​ Boolean)|TrackEndingTrackInteractiveOverlayEventArgs]] ​  | [[ThinkGeo.MapSuite.SilverlightCore.BaseShape|BaseShape]],​ Boolean ​  ​| ​   | This is the commonly used constructor. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Cancel|Cancel]] ​  | Boolean ​  ​| ​   | This property gets or sets the action to be canceled or not.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Shape|Shape]] ​  | [[ThinkGeo.MapSuite.SilverlightCore.BaseShape|BaseShape]] ​  ​| ​   | This property gets or sets the shape to be tracking out.   |
-==== TrackEndingTrackInteractiveOverlayEventArgs() ====
-=== Remarks ===
-=== Parameters ===
-==== TrackEndingTrackInteractiveOverlayEventArgs(BaseShape,​ Boolean) ====
-=== Parameters ===
-| shape   | [[ThinkGeo.MapSuite.SilverlightCore.BaseShape|BaseShape]]<​!-- ThinkGeo.MapSuite.SilverlightCore.BaseShape --> ​  | This parameter specified the shape to be tracking out.   |
-| cancel ​  | Boolean<​!-- System.Boolean --> ​  | This parameter specified the cancel property. ​  |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Cancel ====
-This property gets or sets the action to be canceled or not.
-^ Return Type ^
-<!-- ThinkGeo.MapSuite.SilverlightEdition.TrackEndingTrackInteractiveOverlayEventArgs -->
-==== Shape ====
-This property gets or sets the shape to be tracking out.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.SilverlightCore.BaseShape|BaseShape]]<​!-- ThinkGeo.MapSuite.SilverlightCore.BaseShape --> ​  |
-===== Public Events =====
-__NOTOC__
-[[Category:​SilverlightEdition]]
-[[Category:​ThinkGeo.MapSuite.SilverlightEdition]]
thinkgeo.mapsuite.silverlightedition.trackendingtrackinteractiveoverlayeventargs.1440040135.txt.gz ยท Last modified: 2015/09/21 03:29 (external edit)
