thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs [2015/09/21 03:29]
-====== ThinkGeo.MapSuite.SilverlightEdition.MouseMovedTrackInteractiveOverlayEventArgs ======
-Provides data for the MouseMoved. event.
-  *System.Object
-    *System.EventArgs
-      ***ThinkGeo.MapSuite.SilverlightEdition.MouseMovedTrackInteractiveOverlayEventArgs**
-** {{wiki:​PublicMethod.gif|}} MouseMovedTrackInteractiveOverlayEventArgs() **
-== Remarks ==
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} MouseMovedTrackInteractiveOverlayEventArgs(Vertex,​Feature) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​movedVertex//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.Vertex|Vertex]]
-    * Description:​This parameter specified the target vertex to be moved.
-  * //​affectedFeature//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]]
-    * Description:​This parameter specified the affected feature.
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} MovedVertex **
-This property gets or sets the vertex to be moved.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} AffectedFeature **
-This property gets or sets the Feature to be affected.
-== Remarks ==
-N/A
-== Return Value ==
thinkgeo.mapsuite.silverlightedition.mousemovedtrackinteractiveoverlayeventargs.1442806148.txt.gz ยท Last modified: 2015/09/21 03:29 by admin
