thinkgeo.mapsuite.silverlightedition.mapmousewheelinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.mapmousewheelinteractiveoverlayeventargs [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs ======
-<!-- Class -->
-Provides data for the MapMouseWheel event.
-*System.Object
-**System.EventArgs
-***[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​MapMouseWheelInteractiveOverlayEventArgs()|MapMouseWheelInteractiveOverlayEventArgs]] ​  ​| ​   |    | This is the default constructor of this parameter. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​MapMouseWheelInteractiveOverlayEventArgs(InteractionArguments)|MapMouseWheelInteractiveOverlayEventArgs]] ​  | [[ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments|InteractionArguments]] ​  ​| ​   | This is the commonly used constructor. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​InteractionArguments|InteractionArguments]] ​  | [[ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments|InteractionArguments]] ​  ​| ​   | This property gets the interaction auguments for the event args.   |
-==== MapMouseWheelInteractiveOverlayEventArgs() ====
-=== Remarks ===
-=== Parameters ===
-==== MapMouseWheelInteractiveOverlayEventArgs(InteractionArguments) ====
-=== Parameters ===
-| interactionArguments ​  | [[ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments|InteractionArguments]]<​!-- ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments --> ​  | This parameter specified the interaction auguments to construct the class. ​  |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== InteractionArguments ====
-This property gets the interaction auguments for the event args.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments|InteractionArguments]]<​!-- ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments --> ​  |
-<!-- ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs -->
-===== Public Events =====
-__NOTOC__
-[[Category:​SilverlightEdition]]
-[[Category:​ThinkGeo.MapSuite.SilverlightEdition]]
thinkgeo.mapsuite.silverlightedition.mapmousewheelinteractiveoverlayeventargs.1440040134.txt.gz ยท Last modified: 2015/09/21 03:28 (external edit)
