thinkgeo.mapsuite.silverlightedition.mapmousemoveinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.mapmousemoveinteractiveoverlayeventargs [2015/09/21 03:28]
-====== ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs ======
-Provides data for the MapMouseMove event.
-  *System.Object
-    *System.EventArgs
-      ***ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs**
-** {{wiki:​PublicMethod.gif|}} MapMouseMoveInteractiveOverlayEventArgs() **
-== Remarks ==
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} MapMouseMoveInteractiveOverlayEventArgs(Feature,​ControlPointType) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​editingFeature//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]]
-    * Description:​This parameter specified the editing feature to construct the class.
-  * //​controlPointType//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.ControlPointType|ControlPointType]]
-    * Description:​This parameter specified the controlPointType to construct the class.
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} ControlPointType **
-This property gets the ControlPointType for the event args.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} EditingFeature **
-This property gets the EditingFeature for the event args.
-== Remarks ==
-N/A
-== Return Value ==
thinkgeo.mapsuite.silverlightedition.mapmousemoveinteractiveoverlayeventargs.1442806110.txt.gz ยท Last modified: 2015/09/21 03:28 by admin
