thinkgeo.mapsuite.silverlightedition.mapmousedowninteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.mapmousedowninteractiveoverlayeventargs [2015/09/21 03:28]
-====== ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs ======
-Provides data for the MapMouseDown event.
-  *System.Object
-    *System.EventArgs
-      ***ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs**
-** {{wiki:​PublicMethod.gif|}} MapMouseDownInteractiveOverlayEventArgs() **
-== Remarks ==
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} MapMouseDownInteractiveOverlayEventArgs(InteractionArguments) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​interactionArguments//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments|InteractionArguments]]
-    * Description:​This parameter specified the interaction auguments to construct the class.
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} InteractionArguments **
-This property gets the interaction auguments for the event args.
-== Remarks ==
-N/A
-== Return Value ==
thinkgeo.mapsuite.silverlightedition.mapmousedowninteractiveoverlayeventargs.1442806109.txt.gz ยท Last modified: 2015/09/21 03:28 by admin
