thinkgeo.mapsuite.silverlightedition.interactiveoverlay
thinkgeo.mapsuite.silverlightedition.interactiveoverlay [2015/09/21 03:28]
-====== ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay ======
-This class inherits from Overlay abstract class. This specified overlay describle the interative process with MapControl using Mouse or Keyborad.
-  *System.Object
-    *ThinkGeo.MapSuite.SilverlightEdition.Overlay
-      ***ThinkGeo.MapSuite.SilverlightEdition.InteractiveOverlay**
-        *[[ThinkGeo.MapSuite.SilverlightEdition.EditInteractiveOverlay]]
-        *[[ThinkGeo.MapSuite.SilverlightEdition.ExtentInteractiveOverlay]]
-        *[[ThinkGeo.MapSuite.SilverlightEdition.TrackInteractiveOverlay]]
-** {{wiki:​ProtectedMethod.gif|}} InteractiveOverlay() **
-Default constructor of this abstract class.
-== Remarks ==
-N/A
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} MouseDown(InteractionArguments) **
-This method will simulate the MouseDown interaction.
-== Remarks ==
-This method is the concrete wrapper for its virtual Core method. As this is a concrete public method that wraps a Core method, we reserve the right to add events and other logic to pre- or post-process data returned by the Core version of the method. In this way, we leave our framework open on our end, but also allow you the developer to extend our logic to suit your needs. If you have questions about this, please contact our support team as we would be happy to work with you on extending our framework.
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.InteractiveResult|InteractiveResult]]
-  * Description:​Interaction results of this method.
-== Parameters ==
-  * //​interactionArguments//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.InteractionArguments|InteractionArguments]]
-    * Description:​This parameter is the interaction auguments for the method.
-** {{wiki:​PublicMethod.gif|}} MouseMove(InteractionArguments) **
-This method will simulate the MouseMove interaction.
-== Remarks ==
-== Return Value ==
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} MouseUp(InteractionArguments) **
-This method will simulate the MouseUp interaction.
-== Remarks ==
-== Return Value ==
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} MouseClick(InteractionArguments) **
-This method will simulate the MouseClick interaction.
-== Remarks ==
-== Return Value ==
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} MouseDoubleClick(InteractionArguments) **
-This method will simulate the MouseDoubleClick interaction.
-== Remarks ==
-== Return Value ==
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} MouseWheel(InteractionArguments) **
-This method will simulate the MouseWheel interaction.
-== Remarks ==
-== Return Value ==
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} Refresh() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-  * Description:​N/​A
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} Draw(RectangleShape,​OverlayDrawType) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​worldExtent//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.RectangleShape|RectangleShape]]
-  * //​overlayDrawType//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.OverlayDrawType|OverlayDrawType]]
-** {{wiki:​PublicMethod.gif|}} Initialize(Map) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​currentMap//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.Map|Map]]
-** {{wiki:​PublicMethod.gif|}} ToWorldCoordinate(Double,​Double) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.SilverlightCore.PointShape|PointShape]]
-== Parameters ==
-  * //screenX//
-    * Type:Double
-  * //screenY//
-    * Type:Double
-** {{wiki:​PublicMethod.gif|}} ToWorldCoordinate(PointShape) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​screenCoordinate//​
-** {{wiki:​PublicMethod.gif|}} ToWorldCoordinate(Point) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-    * Type:Point
-** {{wiki:​PublicMethod.gif|}} ToScreenCoordinate(Double,​Double) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //worldX//
-    * Type:Double
-  * //worldY//
-    * Type:Double
-** {{wiki:​PublicMethod.gif|}} ToScreenCoordinate(PointShape) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​worldCoordinate//​
-** {{wiki:​PublicMethod.gif|}} ToScreenCoordinate(Point) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-    * Type:Point
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MouseDownCore(InteractionArguments) **
-This protected virtual method is the Core method of MouseDown API.
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MouseMoveCore(InteractionArguments) **
-This protected virtual method is the Core method of MouseMove API.
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MouseUpCore(InteractionArguments) **
-This protected virtual method is the Core method of MouseUp API.
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MouseClickCore(InteractionArguments) **
-This protected virtual method is the Core method of MouseClick API.
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MouseDoubleClickCore(InteractionArguments) **
-This protected virtual method is the Core method of MouseDoubleClick API.
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MouseWheelCore(InteractionArguments) **
-This protected virtual method is the Core method of MouseWheel API.
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} OnMapMouseDown(MapMouseDownInteractiveOverlayEventArgs) **
-This event will be fired when MapMouseDown is called.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs|MapMouseDownInteractiveOverlayEventArgs]]
-    * Description:​The MapMouseDownInteractiveOverlayEventArgs passed for the event raised.
-** {{wiki:​ProtectedMethod.gif|}} OnMapMouseMove(MapMouseMoveInteractiveOverlayEventArgs) **
-This event will be fired when MapMouseMove is called.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs|MapMouseMoveInteractiveOverlayEventArgs]]
-    * Description:​The MapMouseMoveInteractiveOverlayEventArgs passed for the event raised.
-** {{wiki:​ProtectedMethod.gif|}} OnMapMouseUp(MapMouseUpInteractiveOverlayEventArgs) **
-This event will be fired when MapMouseUp is called.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseUpInteractiveOverlayEventArgs|MapMouseUpInteractiveOverlayEventArgs]]
-    * Description:​The MapMouseUpInteractiveOverlayEventArgs passed for the event raised.
-** {{wiki:​ProtectedMethod.gif|}} OnMapMouseClick(MapMouseClickInteractiveOverlayEventArgs) **
-This event will be fired when MapMouseClick is called.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseClickInteractiveOverlayEventArgs|MapMouseClickInteractiveOverlayEventArgs]]
-    * Description:​The MapMouseClickInteractiveOverlayEventArgs passed for the event raised.
-** {{wiki:​ProtectedMethod.gif|}} OnMapMouseDoubleClick(MapMouseDoubleClickInteractiveOverlayEventArgs) **
-This event will be fired when MapMouseDoubleClick is called.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseDoubleClickInteractiveOverlayEventArgs|MapMouseDoubleClickInteractiveOverlayEventArgs]]
-    * Description:​The MapMouseDoubleClickInteractiveOverlayEventArgs passed for the event raised.
-** {{wiki:​ProtectedMethod.gif|}} OnMapMouseWheel(MapMouseWheelInteractiveOverlayEventArgs) **
-This event will be fired when MapMouseWheel is called.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //e//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs|MapMouseWheelInteractiveOverlayEventArgs]]
-    * Description:​The MapMouseWheelInteractiveOverlayEventArgs passed for the event raised.
-** {{wiki:​ProtectedMethod.gif|}} DrawCore(RectangleShape) **
-This method draws the InterativeInterativeOverlay abstract class. You have to override this API in its sub concrete classes, or it will throw NotImplementedException.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-  * Description:​None
-== Parameters ==
-    * Description:​This parameter is the canvas object or a GeoImage to draw on.
-** {{wiki:​ProtectedMethod.gif|}} DxU=(GeoCanvas) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //canvas//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.GeoCanvas|GeoCanvas]]
-** {{wiki:​ProtectedMethod.gif|}} DrawAttributionCore(GeoCanvas) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //canvas//
-** {{wiki:​ProtectedMethod.gif|}} OnDrawingAttribution(DrawingAttributionOverlayEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.DrawingAttributionOverlayEventArgs|DrawingAttributionOverlayEventArgs]]
-** {{wiki:​ProtectedMethod.gif|}} OnDrawnAttribution(DrawnAttributionOverlayEventArgs) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //args//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.DrawnAttributionOverlayEventArgs|DrawnAttributionOverlayEventArgs]]
-** {{wiki:​ProtectedMethod.gif|}} ZoomStoryCompletedCore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} PanAnimationCompletedCore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} InitializeCore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} MouseMoveInterval **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​TimeSpan
-** {{wiki:​PublicProperty.gif|}} Visibility **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Visibility
-** {{wiki:​PublicProperty.gif|}} OverlayElement **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​FrameworkElement
-** {{wiki:​PublicProperty.gif|}} Name **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Attribution **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} TransitionEffect **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.SilverlightEdition.TransitionEffect|TransitionEffect]]
-** {{wiki:​PublicProperty.gif|}} Opacity **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Double
-** {{wiki:​PublicProperty.gif|}} ZIndex **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} StoryboardForZooming **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Storyboard
-** {{wiki:​PublicProperty.gif|}} StoryboardForPanning **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} PanFrameX **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​SplineDoubleKeyFrame
-** {{wiki:​PublicProperty.gif|}} PanFrameY **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} ZoomFrameX **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} ZoomFrameY **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} MapInfo **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​ProtectedProperty.gif|}} TranslateTransform **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​TranslateTransform
-** {{wiki:​ProtectedProperty.gif|}} ScaleTransform **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​ScaleTransform
-** {{wiki:​ProtectedProperty.gif|}} TransformGroup **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​TransformGroup
-** {{wiki:​PublicEvent.gif|}} MapMouseDown **
-This event will be fired when Mouse pressed Down on the Map.
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseDownInteractiveOverlayEventArgs|MapMouseDownInteractiveOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} MapMouseMove **
-This event will be fired when Mouse moved on the Map.
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseMoveInteractiveOverlayEventArgs|MapMouseMoveInteractiveOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} MapMouseUp **
-This event will be fired when Mouse released up on the Map.
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseUpInteractiveOverlayEventArgs|MapMouseUpInteractiveOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} MapMouseClick **
-This event will be fired when Mouse clicked(mouse up and mouse down in the same postion) on the Map.
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseClickInteractiveOverlayEventArgs|MapMouseClickInteractiveOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} MapMouseDoubleClick **
-This event will be fired when Mouse double clicked on the Map.
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseDoubleClickInteractiveOverlayEventArgs|MapMouseDoubleClickInteractiveOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} MapMouseWheel **
-This event will be fired when Mouse wheel on the Map.
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.MapMouseWheelInteractiveOverlayEventArgs|MapMouseWheelInteractiveOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} DrawingAttribution **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.DrawingAttributionOverlayEventArgs|DrawingAttributionOverlayEventArgs]]
-** {{wiki:​PublicEvent.gif|}} DrawnAttribution **
-N/A
-== Remarks ==
-N/A
-Event Arguments:​[[ThinkGeo.MapSuite.SilverlightEdition.DrawnAttributionOverlayEventArgs|DrawnAttributionOverlayEventArgs]]
thinkgeo.mapsuite.silverlightedition.interactiveoverlay.1442806090.txt.gz ยท Last modified: 2015/09/21 03:28 by admin
