thinkgeo.mapsuite.silverlightedition.featurerotatingeditinteractiveoverlayeventargs
thinkgeo.mapsuite.silverlightedition.featurerotatingeditinteractiveoverlayeventargs [2015/09/21 03:27]
-====== ThinkGeo.MapSuite.SilverlightEdition.FeatureRotatingEditInteractiveOverlayEventArgs ======
-Provides data for the FeatureRotating. event.
-  *System.Object
-    *System.EventArgs
-      ***ThinkGeo.MapSuite.SilverlightEdition.FeatureRotatingEditInteractiveOverlayEventArgs**
-** {{wiki:​PublicMethod.gif|}} FeatureRotatingEditInteractiveOverlayEventArgs() **
-== Remarks ==
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} FeatureRotatingEditInteractiveOverlayEventArgs(Feature,​Boolean,​PointShape,​PointShape) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​rotatingFeature//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.Feature|Feature]]
-    * Description:​This parameter specified the target feature to be rotated.
-  * //cancel//
-    * Type:​Boolean
-    * Description:​This parameter specified the cancel property.
-  * //​sourceControlPoint//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.PointShape|PointShape]]
-    * Description:​This parameter specified the source control point to be roated.
-  * //​targetControlPoint//​
-    * Description:​This parameter specified the target control point to be roated.
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} RotatingFeature **
-This property gets or sets the Feature to be used to roated.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} SourceControlPoint **
-This property gets or sets the source control point to roate.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} TargetControlPoint **
-This property gets or sets the target control point to roate.
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} Cancel **
-This property gets or sets the action to be canceled or not.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
thinkgeo.mapsuite.silverlightedition.featurerotatingeditinteractiveoverlayeventargs.1442806075.txt.gz · Last modified: 2015/09/21 03:27 by admin
