thinkgeo.mapsuite.silverlightcore.conversion
thinkgeo.mapsuite.silverlightcore.conversion [2015/09/22 08:41]
-====== ThinkGeo.MapSuite.SilverlightCore.Conversion ======
-This static class provides a conversion method to go to and from different units.
-  *System.Object
-    ***ThinkGeo.MapSuite.SilverlightCore.Conversion**
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-<div newline></​div>​
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Type
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}}{{wiki:​Static.gif|}} ConvertMeasureUnits(Double,​DistanceUnit,​DistanceUnit) **
-  * //This method converts from one unit of measure to another.//
-== Remarks ==
-  * //None//
-== Return Value ==
-  * Type:Double
-  * Description:​The return length size, represented in the unit specified in the toUnit parameter.
-== Parameters ==
-  * //amount//
-    * Type:Double
-    * Description:​The total length size, represented in the unit specified in the fromUnit parameter.
-  * //​fromUnit//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.DistanceUnit|DistanceUnit]]
-    * Description:​The unit of measure for the length in the Amount parameter.
-  * //toUnit//
-    * Description:​The unit of measure for the result.
-** {{wiki:​PublicMethod.gif|}}{{wiki:​Static.gif|}} ConvertMeasureUnits(Double,​AreaUnit,​AreaUnit) **
-== Remarks ==
-  * //None//
-== Return Value ==
-  * Type:Double
-  * Description:​The return area size, represented in the unit specified in the toUnit parameter.
-== Parameters ==
-  * //amount//
-    * Type:Double
-    * Description:​The total area size, represented in the unit specified in the fromUnit parameter.
-  * //​fromUnit//​
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.AreaUnit|AreaUnit]]
-    * Description:​The unit of measure for the area in the Amount parameter.
-  * //toUnit//
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}}{{wiki:​Static.gif|}} tRo=(GeographyUnit) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //unit//
-    * Type:​[[ThinkGeo.MapSuite.SilverlightCore.GeographyUnit|GeographyUnit]]
-** {{wiki:​ProtectedMethod.gif|}}{{wiki:​Static.gif|}} tho=(Single) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Double
-== Parameters ==
-  * //degrees//
-    * Type:Single
thinkgeo.mapsuite.silverlightcore.conversion.1442911311.txt.gz ยท Last modified: 2015/09/22 08:41 by admin
