thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlaysetting
thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlaysetting [2015/09/22 08:37]
-====== ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting ======
-A setting for WorldMapKitWmsWebOverlay that contains APIs to set properties of WorldMapKitWmsWebOverlaySetting using in MVC view.
-  *System.Object
-    *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null],​[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null]]
-      *ThinkGeo.MapSuite.MvcEdition.OverlaySetting`2[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null],​[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null]]
-        ***ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting**
-** {{wiki:​PublicMethod.gif|}} WorldMapKitWmsWebOverlaySetting(WorldMapKitWmsWebOverlay) **
-  * //​Initializes a new instance of the WorldMapKitWmsWebOverlaySetting class.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //​worldMapKitWmsWebOverlay//​
-    * Type:​[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay|WorldMapKitWmsWebOverlay]]
-    * Description:​N/​A
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} WebImageFormat(WebImageFormat) **
-  * //Set webImageFormat for Element property and retun the WorldMapKitWmsWebOverlaySetting//​
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlaySetting|WorldMapKitWmsWebOverlaySetting]]
-  * Description:​The setting of WorldMapKitWmsWebOverlaySetting itself
-== Parameters ==
-  * //​webImageFormat//​
-    * Type:​[[ThinkGeo.MapSuite.MvcEdition.WebImageFormat|WebImageFormat]]
-    * Description:​A webImageFormat for Element property
-** {{wiki:​PublicMethod.gif|}} TileWidth(Int32) **
-  * //Set tileWidth for Element property and retun the WorldMapKitWmsWebOverlaySetting//​
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​tileWidth//​
-    * Type:Int32
-    * Description:​A tileWidth for Element property
-** {{wiki:​PublicMethod.gif|}} TileHeight(Int32) **
-  * //Set tileHeight for Element property and retun the WorldMapKitWmsWebOverlaySetting//​
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​tileHeight//​
-    * Type:Int32
-    * Description:​A tileHeight for Element property
-** {{wiki:​PublicMethod.gif|}} TransitionEffect(TransitionEffect) **
-  * //Set transitionEffect for Element property and retun the WorldMapKitWmsWebOverlaySetting//​
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​transitionEffect//​
-    * Type:​[[ThinkGeo.MapSuite.MvcEdition.TransitionEffect|TransitionEffect]]
-    * Description:​A transitionEffect for Element property
-** {{wiki:​PublicMethod.gif|}} TransitionEffectDelayInMilliseconds(Int32) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​transitionEffectDelayInMilliseconds//​
-    * Type:Int32
-** {{wiki:​PublicMethod.gif|}} TileType(TileType) **
-  * //Set tileType for Element property and retun the WorldMapKitWmsWebOverlaySetting//​
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​tileType//​
-    * Type:​[[ThinkGeo.MapSuite.MvcEdition.TileType|TileType]]
-    * Description:​A tileType for Element property
-** {{wiki:​PublicMethod.gif|}} WrapDateline(WrapDatelineMode) **
-  * //Set wrapDateline for Element property and retun the WorldMapKitWmsWebOverlaySetting//​
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​wrapDateline//​
-    * Type:​[[ThinkGeo.MapSuite.MvcEdition.WrapDatelineMode|WrapDatelineMode]]
-    * Description:​A wrapDateline for Element property
-** {{wiki:​PublicMethod.gif|}} Projection(WorldMapKitProjection) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​projection//​
-    * Type:​[[ThinkGeo.MapSuite.Core.WorldMapKitProjection|WorldMapKitProjection]]
-** {{wiki:​PublicMethod.gif|}} IsVisible(Boolean) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​isVisible//​
-    * Type:​Boolean
-** {{wiki:​PublicMethod.gif|}} Name(String) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //name//
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} Opacity(Single) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //opacity//
-    * Type:Single
-** {{wiki:​PublicMethod.gif|}} IsVisibleInOverlaySwitcher(Boolean) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​isVisibleInOverlaySwitcher//​
-    * Type:​Boolean
-** {{wiki:​PublicMethod.gif|}} IsBaseOverlay(Boolean) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​isBaseOverlay//​
-    * Type:​Boolean
-** {{wiki:​PublicMethod.gif|}} Id(String) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //id//
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} OnClientAutoRefreshTick(String) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​clientTickFunctionName//​
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} AutoRefreshInterval(TimeSpan) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-== Parameters ==
-  * //​timeSpan//​
-    * Type:​TimeSpan
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:String
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Type
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​ProtectedProperty.gif|}} Element **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
thinkgeo.mapsuite.mvcedition.worldmapkitwmsweboverlaysetting.1442911049.txt.gz ยท Last modified: 2015/09/22 08:37 by admin
