thinkgeo.mapsuite.mvcedition.panzoombarmaptoolsetting
thinkgeo.mapsuite.mvcedition.panzoombarmaptoolsetting [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting ======
-<!-- Class -->
-A setting for PanZoomBarMapTool that contains APIs to set properties of PanZoomBarMapToolSetting using in MVC view.
-*System.Object
-    * PublicKeyToken=null]]
-      * Culture=neutral
-        * Version=9.0.0.0
-***** MvcEdition
-******[[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting]]
-******* PublicKeyToken=null]
-******** Culture=neutral
-********* Version=9.0.0.0
-********** MvcEdition
-***********[[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool]]
-************ PublicKeyToken=null]]
-************* Culture=neutral
-************** Version=9.0.0.0
-*************** MvcEdition
-****************[[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting]]
-***************** PublicKeyToken=null]
-****************** Culture=neutral
-******************* Version=9.0.0.0
-******************** MvcEdition
-*********************[[ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool]]
-**********************[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​PanZoomBarMapToolSetting(PanZoomBarMapTool)|PanZoomBarMapToolSetting]] ​  | [[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool|PanZoomBarMapTool]] ​  ​| ​   | Initializes a new instance of the PanZoomBarMapToolSetting class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​Enabled(Boolean)|Enabled]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.MapToolSetting|MapToolSetting]]<​[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool|PanZoomBarMapTool]],​[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting|PanZoomBarMapToolSetting]]> ​  ​| ​   |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​IsGlobeButtonEnabled(Boolean)|IsGlobeButtonEnabled]] ​  | Boolean ​  ​| ​   | Set isGlobeButtonEnabled for Element property and retun the PanZoomBarMapToolSetting ​  |
-| {{wiki:​ProtectedProperty.gif|Protected Property}}[[#​Element|Element]] ​  | [[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool|PanZoomBarMapTool]] ​  | [[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase|MvcElementSettingBase]]<​[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool|PanZoomBarMapTool]],​[[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting|PanZoomBarMapToolSetting]]> ​  ​| ​   |
-==== PanZoomBarMapToolSetting(PanZoomBarMapTool) ====
-Initializes a new instance of the PanZoomBarMapToolSetting class.
-=== Parameters ===
-| mapTool ​  | [[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool|PanZoomBarMapTool]]<​!-- ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool --> ​  ​| ​   |
-===== Public Methods =====
-==== Enabled(Boolean) ====
-=== Return Value ===
-| [[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting|PanZoomBarMapToolSetting]]<​!-- ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting --> ​  ​| ​   |
-=== Parameters ===
-| isEnabled ​  | Boolean<​!-- System.Boolean --> ​  ​| ​   |
-<!-- ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool,​ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting} -->
-[[#Public Methods|Go Back]]
-==== Equals(Object) ====
-=== Parameters ===
-<!-- System.Object -->
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== IsGlobeButtonEnabled(Boolean) ====
-Set isGlobeButtonEnabled for Element property and retun the PanZoomBarMapToolSetting
-| [[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting|PanZoomBarMapToolSetting]]<​!-- ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting --> ​  | The setting of PanZoomBarMapToolSetting itself ​  |
-=== Parameters ===
-| isGlobeButtonEnabled ​  | Boolean<​!-- System.Boolean --> ​  | A isGlobeButtonEnabled for Element property ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting -->
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Element ====
-^ Return Type ^
-| [[ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool|PanZoomBarMapTool]]<​!-- ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool --> ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapTool,​ThinkGeo.MapSuite.MvcEdition.PanZoomBarMapToolSetting} -->
-[[#​Protected Properties|Go Back]]
-===== Public Events =====
-__NOTOC__
-[[Category:​MvcEdition]]
-[[Category:​ThinkGeo.MapSuite.MvcEdition]]
thinkgeo.mapsuite.mvcedition.panzoombarmaptoolsetting.1440040131.txt.gz ยท Last modified: 2015/09/21 03:35 (external edit)
