thinkgeo.mapsuite.mvcedition.overlay [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.Overlay ====== | ||
| - | <!-- Class --> | ||
| - | Serves as the base class that defines the properties and methods shared by all types of overlays. | ||
| - | === Remarks === | ||
| - | The <strong>Overlay</strong> has as similar concept to the Layer. Different types of overlays stack over each other to form a map. An overlay object is responsible for getting the configuration information from the user and serializing it to a JSON string to control the client Javascript library, which creates the appropriate client layer. | ||
| - | Usually, an overlay represents an image with a transparent background that is laid upon other overlay, such as a <strong>LayerOverlay</strong> or <strong>WmsOverlay</strong>. While the <strong>MarkerOverlay</strong> will not be rendered as an image, it actually represents a <strong>div</strong> that holds several marker images at the client side. | ||
| - | There are basically two kinds of overlays: base overlays and non-base overlays. | ||
| - | A base overlay has its <strong>IsBaseOverlay</strong> property set to true. It is displayed as the background image of the map. In an <strong>OverlaySwitcher</strong>, there is a radio button beside its name. There can be only one base overlay displayed at a time. You can click the radio button to switch the base overlay that is displayed. | ||
| - | A non-base overlay has a false <strong>IsBaseOverlay</strong> property. These overlays can overlap the base overlay and/or each other. They are displayed in the <strong>OverlaySwitcher</strong> with a check box beside their name. You can click the check box to show or hide a specific overlay. | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.MvcEdition.Overlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.AdornmentOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.BingMapsOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.EditFeatureOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.FeatureSourceMarkerOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.GoogleOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.HighlightFeatureOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.InMemoryMarkerOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.LayerOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.MarkerOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.OpenStreetMapOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.SimpleMarkerOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.WmsOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.WmtsOverlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.WorldMapKitWmsWebOverlay]] | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Overlay()|Overlay]] | | | Initialize an instance of the Overlay class. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Overlay(String)|Overlay]] | String | | Initialize an instance of the Overlay class. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Overlay(String, Boolean)|Overlay]] | String, Boolean | | Initialize an instance of the Overlay class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FromJson(String)|FromJson]] | String | | Load this object from a json string. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | | Returns a JSON string which contains the information for creating an overlay at the client side. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#RegisterJavaScriptLibraryCore(Page)|RegisterJavaScriptLibraryCore]] | Page | | Registers a Javascript library URL string to the client HTML page. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Attribution|Attribution]] | String | | | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#AutoRefreshInterval|AutoRefreshInterval]] | TimeSpan | | Gets or sets the time interval in which the MarkerOverlay refreshes itself. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Id|Id]] | String | | Gets the identifier for the overlay to be found. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#IsBaseOverlay|IsBaseOverlay]] | Boolean | | Gets or sets a value that indicates whether the overlay is a base overlay. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#IsVisible|IsVisible]] | Boolean | | Gets or sets a value that indicates whether the overlay is visible on the map. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#IsVisibleInOverlaySwitcher|IsVisibleInOverlaySwitcher]] | Boolean | | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Name|Name]] | String | | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#OnClientAutoRefreshTick|OnClientAutoRefreshTick]] | String | | Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Opacity|Opacity]] | Single | | Gets or sets the opacity level of the overlay. | | ||
| - | | {{wiki:ProtectedProperty.gif|Protected Property}}[[#OverlayType|OverlayType]] | String | | Gets a string that indicates which type the overlay is. | | ||
| - | ==== Overlay() ==== | ||
| - | Initialize an instance of the Overlay class. | ||
| - | === Overloads === | ||
| - | === Parameters === | ||
| - | [[#Protected Constructors|Go Back]] | ||
| - | ==== Overlay(String) ==== | ||
| - | | id | String<!-- System.String --> | | | ||
| - | ==== Overlay(String, Boolean) ==== | ||
| - | | isBaseOverlay | Boolean<!-- System.Boolean --> | | | ||
| - | ==== FromJson(String) ==== | ||
| - | Load this object from a json string. | ||
| - | | jsonString | String<!-- System.String --> | a json string | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.Overlay --> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string which contains the information for creating an overlay at the client side. | ||
| - | | String<!-- System.String --> | A JSON string which is used to create an overlay at the client side. | | ||
| - | ==== RegisterJavaScriptLibraryCore(Page) ==== | ||
| - | Registers a Javascript library URL string to the client HTML page. | ||
| - | The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page. | ||
| - | | page | Page<!-- System.Web.UI.Page --> | The page object that is used for registering the javascript library. | | ||
| - | ==== Attribution ==== | ||
| - | ^ Return Type ^ | ||
| - | | String<!-- System.String --> | | ||
| - | ==== AutoRefreshInterval ==== | ||
| - | Gets or sets the time interval in which the MarkerOverlay refreshes itself. | ||
| - | | TimeSpan<!-- System.TimeSpan --> | | ||
| - | ==== Id ==== | ||
| - | Gets the identifier for the overlay to be found. | ||
| - | ==== IsBaseOverlay ==== | ||
| - | Gets or sets a value that indicates whether the overlay is a base overlay. | ||
| - | ==== IsVisible ==== | ||
| - | Gets or sets a value that indicates whether the overlay is visible on the map. | ||
| - | ==== IsVisibleInOverlaySwitcher ==== | ||
| - | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. | ||
| - | ==== Name ==== | ||
| - | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. | ||
| - | ==== OnClientAutoRefreshTick ==== | ||
| - | Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed. | ||
| - | ==== Opacity ==== | ||
| - | Gets or sets the opacity level of the overlay. | ||
| - | The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible. | ||
| - | | Single<!-- System.Single --> | | ||
| - | ==== OverlayType ==== | ||
| - | Gets a string that indicates which type the overlay is. | ||
| - | [[#Protected Properties|Go Back]] | ||
| - | __NOTOC__ | ||
