thinkgeo.mapsuite.mvcedition.multithreadtileresource [2015/09/22 08:35] admin |
| - | ====== ThinkGeo.MapSuite.MvcEdition.MultiThreadTileResource ====== | ||
| - | This is an asynchronous HTTP handler which is used to handle web map services. | ||
| - | *System.Object | ||
| - | ***ThinkGeo.MapSuite.MvcEdition.MultiThreadTileResource** | ||
| - | ** {{wiki:PublicMethod.gif|}} MultiThreadTileResource() ** | ||
| - | * //This is the default constructor for the TileResource class.// | ||
| - | == Remarks == | ||
| - | == Parameters == | ||
| - | ** {{wiki:PublicMethod.gif|}} ProcessRequest(HttpContext) ** | ||
| - | * //Enables processing of HTTP Web requests by a custom HttpHandler.// | ||
| - | * //N/A// | ||
| - | == Return Value == | ||
| - | * Type:Void | ||
| - | * Description:N/A | ||
| - | * //context// | ||
| - | * Type:HttpContext | ||
| - | * Description:A System.Web.HttpContext object that provides references to the intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. | ||
| - | ** {{wiki:PublicMethod.gif|}} BeginProcessRequest(HttpContext,AsyncCallback,Object) ** | ||
| - | * //Initiates an asynchronous call to the HTTP handler.// | ||
| - | * //N/A// | ||
| - | * Type:IAsyncResult | ||
| - | * Description:A System.IAsyncResult that contains information about the status of the process. | ||
| - | * Description:A System.Web.HttpContext object that provides references to intrinsic server objects (for example: Request, Response, Session, and Server) used to service HTTP requests. | ||
| - | * //cb// | ||
| - | * Type:AsyncCallback | ||
| - | * Description:The System.AsyncCallback to call when the asynchronous method call is complete. If cb is null, the delegate is not called. | ||
| - | * //extraData// | ||
| - | * Type:Object | ||
| - | * Description:Any extra data needed to process the request. | ||
| - | ** {{wiki:PublicMethod.gif|}} EndProcessRequest(IAsyncResult) ** | ||
| - | * //Provides an asynchronous process End method when the process ends.// | ||
| - | * //N/A// | ||
| - | * //result// | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * Type:String | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * Type:Boolean | ||
| - | * //obj// | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * Type:Int32 | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * Type:Type | ||
| - | ** {{wiki:ProtectedMethod.gif|}} ProcessRequestCore(HttpContext) ** | ||
| - | * //N/A// | ||
| - | ** {{wiki:ProtectedMethod.gif|}} BeginProcessRequestCore(HttpContext,AsyncCallback,Object) ** | ||
| - | * //N/A// | ||
| - | * //cb// | ||
| - | ** {{wiki:ProtectedMethod.gif|}} EndProcessRequestCore(IAsyncResult) ** | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | * //N/A// | ||
| - | ** {{wiki:PublicProperty.gif|}} IsReusable ** | ||
| - | Gets a value indicating whether another request can use the System.Web.IHttpAsyncHandler instance. | ||
| - | N/A | ||
