thinkgeo.mapsuite.mvcedition.minimapmaptoolsetting [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting ====== | ||
| - | <!-- Class --> | ||
| - | A setting for MiniMapMapTool that contains APIs to set properties of MiniMapMapToolSetting using in MVC view. | ||
| - | *System.Object | ||
| - | * PublicKeyToken=null]] | ||
| - | * Culture=neutral | ||
| - | * Version=9.0.0.0 | ||
| - | ***** MvcEdition | ||
| - | ******[[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting]] | ||
| - | ******* PublicKeyToken=null] | ||
| - | ******** Culture=neutral | ||
| - | ********* Version=9.0.0.0 | ||
| - | ********** MvcEdition | ||
| - | ***********[[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool]] | ||
| - | ************ PublicKeyToken=null]] | ||
| - | ************* Culture=neutral | ||
| - | ************** Version=9.0.0.0 | ||
| - | *************** MvcEdition | ||
| - | ****************[[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting]] | ||
| - | ***************** PublicKeyToken=null] | ||
| - | ****************** Culture=neutral | ||
| - | ******************* Version=9.0.0.0 | ||
| - | ******************** MvcEdition | ||
| - | *********************[[ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool]] | ||
| - | **********************[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MiniMapMapToolSetting(MiniMapMapTool)|MiniMapMapToolSetting]] | [[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool|MiniMapMapTool]] | | Initializes a new instance of the MiniMapMapToolSetting class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Enabled(Boolean)|Enabled]] | Boolean | [[ThinkGeo.MapSuite.MvcEdition.MapToolSetting|MapToolSetting]]<[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool|MiniMapMapTool]],[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting|MiniMapMapToolSetting]]> | | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MaximizeRatio(Int32)|MaximizeRatio]] | Int32 | | Set maximize Ratio of map for Element property and retun the MiniMapMapToolSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MinimizeRatio(Int32)|MinimizeRatio]] | Int32 | | Set minimize Ratio of map for Element property and retun the MiniMapMapToolSetting | | ||
| - | | {{wiki:ProtectedProperty.gif|Protected Property}}[[#Element|Element]] | [[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool|MiniMapMapTool]] | [[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase|MvcElementSettingBase]]<[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool|MiniMapMapTool]],[[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting|MiniMapMapToolSetting]]> | | | ||
| - | ==== MiniMapMapToolSetting(MiniMapMapTool) ==== | ||
| - | Initializes a new instance of the MiniMapMapToolSetting class. | ||
| - | === Parameters === | ||
| - | | mapTool | [[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool|MiniMapMapTool]]<!-- ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool --> | | | ||
| - | ==== Enabled(Boolean) ==== | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting|MiniMapMapToolSetting]]<!-- ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting --> | | | ||
| - | | isEnabled | Boolean<!-- System.Boolean --> | | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool,ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting} --> | ||
| - | ==== MaximizeRatio(Int32) ==== | ||
| - | Set maximize Ratio of map for Element property and retun the MiniMapMapToolSetting | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting|MiniMapMapToolSetting]]<!-- ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting --> | The setting of MiniMapMapToolSetting itself | | ||
| - | | maximizeRatio | Int32<!-- System.Int32 --> | A maximize Ratio of map for Element property | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting --> | ||
| - | ==== MinimizeRatio(Int32) ==== | ||
| - | Set minimize Ratio of map for Element property and retun the MiniMapMapToolSetting | ||
| - | | minimizeRatio | Int32<!-- System.Int32 --> | A minimize Ratio of map for Element property | | ||
| - | ==== Element ==== | ||
| - | ^ Return Type ^ | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool|MiniMapMapTool]]<!-- ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool --> | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.MiniMapMapTool,ThinkGeo.MapSuite.MvcEdition.MiniMapMapToolSetting} --> | ||
| - | [[#Protected Properties|Go Back]] | ||
| - | __NOTOC__ | ||
