thinkgeo.mapsuite.mvcedition.measuremaptool
thinkgeo.mapsuite.mvcedition.measuremaptool [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.MvcEdition.MeasureMapTool ======
-<!-- Class -->
-Represents the measure map tool which allows measurements for features.
-*System.Object
-**[[ThinkGeo.MapSuite.MvcEdition.MapTool]]
-***[[ThinkGeo.MapSuite.MvcEdition.MeasureMapTool]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​MeasureMapTool()|MeasureMapTool]] ​  ​| ​   |    | Initialize an instance of the MeasureMapTool class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​FromJson(String)|FromJson]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] ​  | Load this object from a json string. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ToJson()|ToJson]] ​  ​| ​   | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] ​  | Returns a JSON string that represents the map control object. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Enabled|Enabled]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] ​  | Gets or sets a value that turns the feature on and off.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Geodesic|Geodesic]] ​  | Boolean ​  ​| ​   | Indicate whether to measure geodesic distance. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​MeasureType|MeasureType]] ​  | [[ThinkGeo.MapSuite.MvcEdition.MeasureType|MeasureType]] ​  ​| ​   | Represents the different types of the MeasureMapTool. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​MeasureUnitType|MeasureUnitType]] ​  | [[ThinkGeo.MapSuite.MvcEdition.MeasureUnitType|MeasureUnitType]] ​  ​| ​   | Represents the display system units for output measurements. ​  |
-==== MeasureMapTool() ====
-Initialize an instance of the MeasureMapTool class.
-=== Remarks ===
-The default MeasureType is Line, and the display system units is Metric by default, also it measures geodesic distance by default.
-=== Parameters ===
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== FromJson(String) ====
-Load this object from a json string.
-=== Parameters ===
-| jsonString ​  | String<​!-- System.String --> ​  | a json string ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.MapTool -->
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToJson() ====
-Returns a JSON string that represents the map control object.
-=== Remarks ===
-This method returns a JSON string that instructs the client Javascript to create a specific client object.
-| String<​!-- System.String --> ​  | A JSON string that represents the map control. ​  |
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Enabled ====
-Gets or sets a value that turns the feature on and off.
-^ Return Type ^
-==== Geodesic ====
-Indicate whether to measure geodesic distance.
-^ Return Type ^
-<!-- ThinkGeo.MapSuite.MvcEdition.MeasureMapTool -->
-==== MeasureType ====
-Represents the different types of the MeasureMapTool.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.MvcEdition.MeasureType|MeasureType]]<​!-- ThinkGeo.MapSuite.MvcEdition.MeasureType --> ​  |
-==== MeasureUnitType ====
-Represents the display system units for output measurements.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.MvcEdition.MeasureUnitType|MeasureUnitType]]<​!-- ThinkGeo.MapSuite.MvcEdition.MeasureUnitType --> ​  |
-===== Public Events =====
-__NOTOC__
-[[Category:​MvcEdition]]
-[[Category:​ThinkGeo.MapSuite.MvcEdition]]
thinkgeo.mapsuite.mvcedition.measuremaptool.1440040131.txt.gz ยท Last modified: 2015/09/21 03:34 (external edit)
