thinkgeo.mapsuite.mvcedition.loadingimagemaptoolsetting
thinkgeo.mapsuite.mvcedition.loadingimagemaptoolsetting [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting ======
-<!-- Class -->
-A setting for LoadingImageMapTool that contains APIs to set properties of LoadingImageMapToolSetting using in MVC view.
-*System.Object
-    * PublicKeyToken=null]]
-      * Culture=neutral
-        * Version=9.0.0.0
-***** MvcEdition
-******[[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting]]
-******* PublicKeyToken=null]
-******** Culture=neutral
-********* Version=9.0.0.0
-********** MvcEdition
-***********[[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool]]
-************ PublicKeyToken=null]]
-************* Culture=neutral
-************** Version=9.0.0.0
-*************** MvcEdition
-****************[[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting]]
-***************** PublicKeyToken=null]
-****************** Culture=neutral
-******************* Version=9.0.0.0
-******************** MvcEdition
-*********************[[ThinkGeo.MapSuite.MvcEdition.MapToolSetting`2[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool]]
-**********************[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​LoadingImageMapToolSetting(LoadingImageMapTool)|LoadingImageMapToolSetting]] ​  | [[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool|LoadingImageMapTool]] ​  ​| ​   | Initializes a new instance of the LoadingImageMapToolSetting class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​Enabled(Boolean)|Enabled]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.MapToolSetting|MapToolSetting]]<​[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool|LoadingImageMapTool]],​[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting|LoadingImageMapToolSetting]]> ​  ​| ​   |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​Height(Int32)|Height]] ​  | Int32   ​| ​   | Set height for Element property and retun the LoadingImageMapToolSetting ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ImageUri(Uri)|ImageUri]] ​  | Uri   ​| ​   | Set imageUri for Element property and retun the LoadingImageMapToolSetting ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​Width(Int32)|Width]] ​  | Int32   ​| ​   | Set width for Element property and retun the LoadingImageMapToolSetting ​  |
-| {{wiki:​ProtectedProperty.gif|Protected Property}}[[#​Element|Element]] ​  | [[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool|LoadingImageMapTool]] ​  | [[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase|MvcElementSettingBase]]<​[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool|LoadingImageMapTool]],​[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting|LoadingImageMapToolSetting]]> ​  ​| ​   |
-==== LoadingImageMapToolSetting(LoadingImageMapTool) ====
-Initializes a new instance of the LoadingImageMapToolSetting class.
-=== Parameters ===
-| mapTool ​  | [[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool|LoadingImageMapTool]]<​!-- ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool --> ​  | the map Tool which will be assigned to Element property ​  |
-===== Public Methods =====
-==== Enabled(Boolean) ====
-=== Return Value ===
-| [[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting|LoadingImageMapToolSetting]]<​!-- ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting --> ​  ​| ​   |
-=== Parameters ===
-| isEnabled ​  | Boolean<​!-- System.Boolean --> ​  ​| ​   |
-<!-- ThinkGeo.MapSuite.MvcEdition.MapToolSetting{ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool,​ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting} -->
-[[#Public Methods|Go Back]]
-==== Equals(Object) ====
-=== Parameters ===
-<!-- System.Object -->
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== Height(Int32) ====
-Set height for Element property and retun the LoadingImageMapToolSetting
-| [[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting|LoadingImageMapToolSetting]]<​!-- ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting --> ​  | The setting of LoadingImageMapToolSetting itself ​  |
-=== Parameters ===
-| height ​  | Int32<​!-- System.Int32 --> ​  | A height for Element property ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting -->
-==== ImageUri(Uri) ====
-Set imageUri for Element property and retun the LoadingImageMapToolSetting
-=== Parameters ===
-| imageUri ​  | Uri<!-- System.Uri --> ​  | A imageUri for Element property ​  |
-==== ToString() ====
-=== Parameters ===
-==== Width(Int32) ====
-Set width for Element property and retun the LoadingImageMapToolSetting
-=== Parameters ===
-| width   | Int32<​!-- System.Int32 --> ​  | A width for Element property ​  |
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Element ====
-^ Return Type ^
-| [[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool|LoadingImageMapTool]]<​!-- ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool --> ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool,​ThinkGeo.MapSuite.MvcEdition.LoadingImageMapToolSetting} -->
-[[#​Protected Properties|Go Back]]
-===== Public Events =====
-__NOTOC__
-[[Category:​MvcEdition]]
-[[Category:​ThinkGeo.MapSuite.MvcEdition]]
thinkgeo.mapsuite.mvcedition.loadingimagemaptoolsetting.1440040131.txt.gz ยท Last modified: 2015/09/21 03:33 (external edit)
