thinkgeo.mapsuite.mvcedition.loadingimagemaptool [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool ====== | ||
| - | <!-- Class --> | ||
| - | Represents a small image that displays at the center of the map when the map is loading. | ||
| - | === Remarks === | ||
| - | This map control displays an image at the center of the map, indicating that the map is now busy getting images from the server. Usually the image is in GIF format. | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.MvcEdition.MapTool]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#LoadingImageMapTool()|LoadingImageMapTool]] | | | Initialize an instance of LoadingImageMapTool class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FromJson(String)|FromJson]] | String | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] | Load this object from a json string. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] | Returns a JSON string that represents the map control object. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Enabled|Enabled]] | Boolean | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] | Gets or sets a value that turns the feature on and off. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Height|Height]] | Int32 | | Gets or sets the height of the loading image. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#ImageUri|ImageUri]] | Uri | | Gets or sets the URI of the loading image. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Width|Width]] | Int32 | | Gets or sets the width of the loading image. | | ||
| - | ==== LoadingImageMapTool() ==== | ||
| - | Initialize an instance of LoadingImageMapTool class. | ||
| - | === Parameters === | ||
| - | ==== FromJson(String) ==== | ||
| - | Load this object from a json string. | ||
| - | | jsonString | String<!-- System.String --> | a json string | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MapTool --> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string that represents the map control object. | ||
| - | This method returns a JSON string that instructs the client Javascript to create a specific client object. | ||
| - | | String<!-- System.String --> | A JSON string that represents the map control. | | ||
| - | ==== Enabled ==== | ||
| - | Gets or sets a value that turns the feature on and off. | ||
| - | ^ Return Type ^ | ||
| - | ==== Height ==== | ||
| - | Gets or sets the height of the loading image. | ||
| - | | Int32<!-- System.Int32 --> | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.LoadingImageMapTool --> | ||
| - | ==== ImageUri ==== | ||
| - | Gets or sets the URI of the loading image. | ||
| - | | Uri<!-- System.Uri --> | | ||
| - | ==== Width ==== | ||
| - | Gets or sets the width of the loading image. | ||
| - | __NOTOC__ | ||
