thinkgeo.mapsuite.mvcedition.keyboardmaptool
thinkgeo.mapsuite.mvcedition.keyboardmaptool [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool ======
-<!-- Class -->
-Determines whether the map can be operated by keyboard.
-=== Remarks ===
-The <​strong>​KeyboardMapTool</​strong>​ map control determines whether you can operate the map by keyboard. Set the <​strong>​Enabled</​strong>​ property to true to enable the keyboard support of the map.
-*System.Object
-**[[ThinkGeo.MapSuite.MvcEdition.MapTool]]
-***[[ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​KeyboardMapTool()|KeyboardMapTool]] ​  ​| ​   |    | Initializes a new instance of the KeyboardMapTool class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​FromJson(String)|FromJson]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] ​  | Load this object from a json string. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ToJson()|ToJson]] ​  ​| ​   | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] ​  | Returns a JSON string that represents the map control object. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Enabled|Enabled]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] ​  | Gets or sets a value that turns the feature on and off.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​PanPixels|PanPixels]] ​  | Int32   ​| ​   | Gets or sets the number of pixels that are shifted by each keyboard-based panning operation. ​  |
-==== KeyboardMapTool() ====
-Initializes a new instance of the KeyboardMapTool class.
-=== Remarks ===
-Use this constructor to create and initialize a new instance of the <​strong>​KeyboardMapTool</​strong>​ class.
-=== Parameters ===
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== FromJson(String) ====
-Load this object from a json string.
-=== Parameters ===
-| jsonString ​  | String<​!-- System.String --> ​  | a json string ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.MapTool -->
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToJson() ====
-Returns a JSON string that represents the map control object.
-=== Remarks ===
-This method returns a JSON string that instructs the client Javascript to create a specific client object.
-| String<​!-- System.String --> ​  | A JSON string that represents the map control. ​  |
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Enabled ====
-Gets or sets a value that turns the feature on and off.
-^ Return Type ^
-==== PanPixels ====
-Gets or sets the number of pixels that are shifted by each keyboard-based panning operation.
-=== Remarks ===
-The value of this property determines how many pixels to shift when using the arrow keys to pan.
-^ Return Type ^
-| Int32<​!-- System.Int32 --> ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.KeyboardMapTool -->
-===== Public Events =====
-__NOTOC__
-[[Category:​MvcEdition]]
-[[Category:​ThinkGeo.MapSuite.MvcEdition]]
thinkgeo.mapsuite.mvcedition.keyboardmaptool.1440040131.txt.gz ยท Last modified: 2015/09/21 03:33 (external edit)
