thinkgeo.mapsuite.mvcedition.highlightfeatureoverlay
thinkgeo.mapsuite.mvcedition.highlightfeatureoverlay [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.MvcEdition.HighlightFeatureOverlay ======
-<!-- Class -->
-Represents a FeatureOverlay that can easily apply a highlight style or hook event to the features in it.
-=== Remarks ===
-The <​strong>​HighlightFeatureOverlay</​strong>​ class has a <​strong>​HighlightStyle</​strong>​ property which determines the style of features when you move your mouse over them. By setting this property, you can add an attractive highlight effect.
-The <​strong>​HighlightFeatureOverlay</​strong>​ class also has a <​strong>​Click</​strong>​ event and a <​strong>​ContextMenu</​strong>​ property that can be attached to its features. When you click or right-click on the features, the event will be fired or the context menu will pop up, respectively.
-The <​strong>​OnClientClick</​strong>​ property holds the Javascript that will be executed before the <​strong>​Click</​strong>​ event. If you return <​strong>​false</​strong>​ in the Javascript, the <​strong>​Click</​strong>​ event will not be fired.
-You can only accesss the <​strong>​HighlightFeatureOverlay</​strong>​ instance by using <​strong>​Map.HighlightOverlay</​strong>​. You cannot create an instance by yourself.
-<​strong>​Note:</​strong>​ Because the <​strong>​HighlightFeatureOverlay</​strong>​ serializes and paints all of its features to the client side, there might be a performance impact if you add too many features to its <​strong>​Features</​strong>​ collection.
-*System.Object
-**[[ThinkGeo.MapSuite.MvcEdition.Overlay]]
-***[[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay]]
-****[[ThinkGeo.MapSuite.MvcEdition.HighlightFeatureOverlay]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​FromJson(String)|FromJson]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Load this object from a json string. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​ToJson()|ToJson]] ​  ​| ​   | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Returns a JSON string which contains the information for creating an overlay at the client side.   |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​RegisterJavaScriptLibraryCore(Page)|RegisterJavaScriptLibraryCore]] ​  | Page   | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Registers a Javascript library URL string to the client HTML page.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Attribution|Attribution]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  ​| ​   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​AutoRefreshInterval|AutoRefreshInterval]] ​  | TimeSpan ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets the time interval in which the MarkerOverlay refreshes itself. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Columns|Columns]] ​  | Collection<​[[ThinkGeo.MapSuite.Core.FeatureSourceColumn|FeatureSourceColumn]]> ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay|FeatureOverlay]] ​  | Gets a collection of FeatureSourceColumns,​ which specifies the column names of the feature data.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​ContextMenu|ContextMenu]] ​  | [[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]] ​  ​| ​   | Gets or sets the shortcut menu associated with the HighlightFeatureOverlay. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​EditTools|EditTools]] ​  | [[ThinkGeo.MapSuite.Core.EditTools|EditTools]] ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay|FeatureOverlay]] ​  | Gets the EditTools that allow you to easily edit features in the FeatureOverlay. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​FeatureSource|FeatureSource]] ​  | [[ThinkGeo.MapSuite.Core.InMemoryFeatureSource|InMemoryFeatureSource]] ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay|FeatureOverlay]] ​  | Gets the FeatureSource of the FeatureOverlay. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Features|Features]] ​  | [[ThinkGeo.MapSuite.Core.GeoCollection|GeoCollection]]<​[[ThinkGeo.MapSuite.Core.Feature|Feature]]> ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay|FeatureOverlay]] ​  | Gets a collection of features that will be serialized to the client for drawing and editing. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​HighlightStyle|HighlightStyle]] ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlayStyle|FeatureOverlayStyle]] ​  ​| ​   | Gets or sets a FeatureOverlayStyle that will be applied to the features when the mouse pointer is over them.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Id|Id]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets the identifier for the overlay to be found. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsBaseOverlay|IsBaseOverlay]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets a value that indicates whether the overlay is a base overlay. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsVisible|IsVisible]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets a value that indicates whether the overlay is visible on the map.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​IsVisibleInOverlaySwitcher|IsVisibleInOverlaySwitcher]] ​  | Boolean ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Name|Name]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​OnClientAutoRefreshTick|OnClientAutoRefreshTick]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​OnClientClick|OnClientClick]] ​  | String ​  ​| ​   | Gets or sets the client-side script that executes when the HighlightFeatureOverlay is clicked. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Opacity|Opacity]] ​  | Single ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] ​  | Gets or sets the opacity level of the overlay. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​QueryTools|QueryTools]] ​  | [[ThinkGeo.MapSuite.Core.QueryTools|QueryTools]] ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay|FeatureOverlay]] ​  | Gets the QueryTools that allow you to easily query features from the FeatureOverlay. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Style|Style]] ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlayStyle|FeatureOverlayStyle]] ​  | [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlay|FeatureOverlay]] ​  | Gets or sets a FeatureOverlayStyle object, which determines how the features are drawn at the client side.   |
-| {{wiki:​ProtectedProperty.gif|Protected Property}}[[#​OverlayType|OverlayType]] ​  | String ​  | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]](overriden) ​  ​| ​   |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== FromJson(String) ====
-Load this object from a json string.
-=== Parameters ===
-| jsonString ​  | String<​!-- System.String --> ​  | a json string ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.Overlay -->
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToJson() ====
-Returns a JSON string which contains the information for creating an overlay at the client side.
-| String<​!-- System.String --> ​  | A JSON string which is used to create an overlay at the client side.   |
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== RegisterJavaScriptLibraryCore(Page) ====
-Registers a Javascript library URL string to the client HTML page.
-=== Remarks ===
-The <​strong>​RegisterJavaScriptLibraryCore</​strong>​ method allows derived classes to override and register their own Javascript library URL to the HTML page.
-=== Parameters ===
-| page   | Page<!-- System.Web.UI.Page --> ​  | The page object that is used for registering the javascript library. ​  |
-==== Attribution ====
-^ Return Type ^
-==== AutoRefreshInterval ====
-Gets or sets the time interval in which the MarkerOverlay refreshes itself.
-^ Return Type ^
-| TimeSpan<​!-- System.TimeSpan --> ​  |
-==== Columns ====
-Gets a collection of FeatureSourceColumns,​ which specifies the column names of the feature data.
-^ Return Type ^
-| Collection<​[[ThinkGeo.MapSuite.Core.FeatureSourceColumn|FeatureSourceColumn]]><​!-- System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.Core.FeatureSourceColumn} --> ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.FeatureOverlay -->
-==== ContextMenu ====
-Gets or sets the shortcut menu associated with the HighlightFeatureOverlay.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]]<​!-- ThinkGeo.MapSuite.MvcEdition.ContextMenu --> ​  |
-<!-- ThinkGeo.MapSuite.MvcEdition.HighlightFeatureOverlay -->
-==== EditTools ====
-Gets the EditTools that allow you to easily edit features in the FeatureOverlay.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.Core.EditTools|EditTools]]<​!-- ThinkGeo.MapSuite.Core.EditTools --> ​  |
-==== FeatureSource ====
-Gets the FeatureSource of the FeatureOverlay.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.Core.InMemoryFeatureSource|InMemoryFeatureSource]]<​!-- ThinkGeo.MapSuite.Core.InMemoryFeatureSource --> ​  |
-==== Features ====
-Gets a collection of features that will be serialized to the client for drawing and editing.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.Core.GeoCollection|GeoCollection]]<​[[ThinkGeo.MapSuite.Core.Feature|Feature]]><​!-- ThinkGeo.MapSuite.Core.GeoCollection{ThinkGeo.MapSuite.Core.Feature} --> ​  |
-==== HighlightStyle ====
-Gets or sets a FeatureOverlayStyle that will be applied to the features when the mouse pointer is over them.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.MvcEdition.FeatureOverlayStyle|FeatureOverlayStyle]]<​!-- ThinkGeo.MapSuite.MvcEdition.FeatureOverlayStyle --> ​  |
-==== Id ====
-Gets the identifier for the overlay to be found.
-^ Return Type ^
-==== IsBaseOverlay ====
-Gets or sets a value that indicates whether the overlay is a base overlay.
-^ Return Type ^
-==== IsVisible ====
-Gets or sets a value that indicates whether the overlay is visible on the map.
-^ Return Type ^
-==== IsVisibleInOverlaySwitcher ====
-Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher.
-^ Return Type ^
-==== Name ====
-Gets or sets the name of the overlay, which will display in the OverlaySwitcher.
-^ Return Type ^
-==== OnClientAutoRefreshTick ====
-Gets or sets a JavaScript function name which will be executed when the number of milliseconds specified in the AutoRefreshInterval property has elapsed.
-^ Return Type ^
-==== OnClientClick ====
-Gets or sets the client-side script that executes when the HighlightFeatureOverlay is clicked.
-=== Remarks ===
-There is a default parameter:​e,​ which includes two parameters: "​worldXY",​ "​featureId"​
-^ Return Type ^
-==== Opacity ====
-Gets or sets the opacity level of the overlay.
-=== Remarks ===
-The <​strong>​Opacity</​strong>​ property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
-^ Return Type ^
-| Single<​!-- System.Single --> ​  |
-==== QueryTools ====
-Gets the QueryTools that allow you to easily query features from the FeatureOverlay.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.Core.QueryTools|QueryTools]]<​!-- ThinkGeo.MapSuite.Core.QueryTools --> ​  |
-==== Style ====
-Gets or sets a FeatureOverlayStyle object, which determines how the features are drawn at the client side.
-^ Return Type ^
-==== OverlayType ====
-^ Return Type ^
-<!-- ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) -->
-[[#​Protected Properties|Go Back]]
-===== Public Events =====
-__NOTOC__
-[[Category:​MvcEdition]]
-[[Category:​ThinkGeo.MapSuite.MvcEdition]]
thinkgeo.mapsuite.mvcedition.highlightfeatureoverlay.1440040131.txt.gz ยท Last modified: 2015/09/21 03:33 (external edit)
