thinkgeo.mapsuite.mvcedition.contextmenusetting [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting ====== | ||
| - | <!-- Class --> | ||
| - | A setting for ContextMenu that contains APIs to set properties of ContextMenu using in MVC view. | ||
| - | *System.Object | ||
| - | * PublicKeyToken=null]] | ||
| - | * Culture=neutral | ||
| - | * Version=9.0.0.0 | ||
| - | ***** MvcEdition | ||
| - | ******[[[ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting]] | ||
| - | ******* PublicKeyToken=null] | ||
| - | ******** Culture=neutral | ||
| - | ********* Version=9.0.0.0 | ||
| - | ********** MvcEdition | ||
| - | ***********[[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.ContextMenu]] | ||
| - | ************[[ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ContextMenuSetting(ContextMenu)|ContextMenuSetting]] | [[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]] | | Initializes a new instance of the ContextMenuSetting class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#CssClass(String)|CssClass]] | String | | Set css Class for Element property and retun the ContextMenuSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Id(String)|Id]] | String | | Set Id for Element property and retun the ContextMenuSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MenuItems(Action<ContextMenuItemCollection>)|MenuItems]] | Action<[[ThinkGeo.MapSuite.MvcEdition.ContextMenuItemCollection|ContextMenuItemCollection]]> | | Set Menu Items for Element property according to the input method which takes ContextMenuItemCollection and retun the ContextMenuItemSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Width(Int32)|Width]] | Int32 | | Set width for Element property and retun the ContextMenuSetting | | ||
| - | | {{wiki:ProtectedProperty.gif|Protected Property}}[[#Element|Element]] | [[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]] | [[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase|MvcElementSettingBase]]<[[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]],[[ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting|ContextMenuSetting]]> | | | ||
| - | ==== ContextMenuSetting(ContextMenu) ==== | ||
| - | Initializes a new instance of the ContextMenuSetting class. | ||
| - | === Parameters === | ||
| - | | contextMenu | [[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]]<!-- ThinkGeo.MapSuite.MvcEdition.ContextMenu --> | | | ||
| - | ==== CssClass(String) ==== | ||
| - | Set css Class for Element property and retun the ContextMenuSetting | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting|ContextMenuSetting]]<!-- ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting --> | The setting of ContextMenu itself | | ||
| - | | cssClass | String<!-- System.String --> | A css Class for Element property | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting --> | ||
| - | ==== Id(String) ==== | ||
| - | Set Id for Element property and retun the ContextMenuSetting | ||
| - | | id | String<!-- System.String --> | A id for Element property | | ||
| - | ==== MenuItems(Action<ContextMenuItemCollection>) ==== | ||
| - | Set Menu Items for Element property according to the input method which takes ContextMenuItemCollection and retun the ContextMenuItemSetting | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting|ContextMenuSetting]]<!-- ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting --> | The setting of ContextMenuItem itself | | ||
| - | | addMenuItemAction | Action<[[ThinkGeo.MapSuite.MvcEdition.ContextMenuItemCollection|ContextMenuItemCollection]]><!-- System.Action{ThinkGeo.MapSuite.MvcEdition.ContextMenuItemCollection} --> | A method that takes a ContextMenuItemCollection | | ||
| - | ==== Width(Int32) ==== | ||
| - | Set width for Element property and retun the ContextMenuSetting | ||
| - | | width | Int32<!-- System.Int32 --> | A width for Element property | | ||
| - | ==== Element ==== | ||
| - | ^ Return Type ^ | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.ContextMenu|ContextMenu]]<!-- ThinkGeo.MapSuite.MvcEdition.ContextMenu --> | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.ContextMenu,ThinkGeo.MapSuite.MvcEdition.ContextMenuSetting} --> | ||
| - | [[#Protected Properties|Go Back]] | ||
| - | __NOTOC__ | ||
