thinkgeo.mapsuite.mvcedition.contextmenuitem [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.ContextMenuItem ====== | ||
| - | <!-- Class --> | ||
| - | This class represents a menu item of the ContextMenu control. | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.MvcEdition.ContextMenuItem]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ContextMenuItem()|ContextMenuItem]] | | | Initializes a new instance of the ContextMenuitem. class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ContextMenuItem(String)|ContextMenuItem]] | String | | Initializes a new instance of the ContextMenuitem. class with the innerHtml specified. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ContextMenuItem(String, String)|ContextMenuItem]] | String, String | | Initializes a new instance of the ContextMenuitem. class with the innerHtml and CSS class string specified. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ContextMenuItem(String, String, String)|ContextMenuItem]] | String, String, String | | Initializes a new instance of the ContextMenuitem. class with innerHtml, CSS class and hover CSS class specified. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ContextMenuItem(String, String, String, String)|ContextMenuItem]] | String, String, String, String | | Initializes a new instance of the ContextMenuitem. class with innerHtml, CSS class and hover CSS class specified. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FromJson(String)|FromJson]] | String | | Load this object from a json string. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | | Returns a JSON string that has information for creating the context menu item at the client side. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#CssClass|CssClass]] | String | | Gets or sets the Cascading Style Sheet (CSS) class name string that affects the appearance of the context menu item. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#HoverCssClass|HoverCssClass]] | String | | Gets or sets the Cascading Style Sheet (CSS) class name string that applies when the mouse hovers over the menu item. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Id|Id]] | String | | Gets the identifier of the context menu item. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#InnerHtml|InnerHtml]] | String | | Gets or sets the content HTML of the context menu item. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MenuItems|MenuItems]] | [[ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection|GeoKeyedCollection]]<[[ThinkGeo.MapSuite.MvcEdition.ContextMenuItem|ContextMenuItem]]> | | Gets the menu item collection of the context menu item. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#OnClientClick|OnClientClick]] | String | | Gets or sets the client-side script that executes when a context menu item's Click event is raised. | | ||
| - | ==== ContextMenuItem() ==== | ||
| - | Initializes a new instance of the ContextMenuitem. class. | ||
| - | === Overloads === | ||
| - | === Parameters === | ||
| - | ==== ContextMenuItem(String) ==== | ||
| - | Initializes a new instance of the ContextMenuitem. class with the innerHtml specified. | ||
| - | | innerHtml | String<!-- System.String --> | The innerHtml of the context menu item. | | ||
| - | ==== ContextMenuItem(String, String) ==== | ||
| - | Initializes a new instance of the ContextMenuitem. class with the innerHtml and CSS class string specified. | ||
| - | | cssClass | String<!-- System.String --> | The CSS class of the context menu item. | | ||
| - | ==== ContextMenuItem(String, String, String) ==== | ||
| - | Initializes a new instance of the ContextMenuitem. class with innerHtml, CSS class and hover CSS class specified. | ||
| - | | hoverCssClass | String<!-- System.String --> | The CSS class of the context menu item when the mouse is hovering over it. | | ||
| - | ==== ContextMenuItem(String, String, String, String) ==== | ||
| - | | id | String<!-- System.String --> | The id of the context menu item. | | ||
| - | ==== FromJson(String) ==== | ||
| - | Load this object from a json string. | ||
| - | | jsonString | String<!-- System.String --> | a json string | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.ContextMenuItem --> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string that has information for creating the context menu item at the client side. | ||
| - | | String<!-- System.String --> | A JSON string for creating the context menu item at the client side. | | ||
| - | ==== CssClass ==== | ||
| - | Gets or sets the Cascading Style Sheet (CSS) class name string that affects the appearance of the context menu item. | ||
| - | ^ Return Type ^ | ||
| - | | String<!-- System.String --> | | ||
| - | ==== HoverCssClass ==== | ||
| - | Gets or sets the Cascading Style Sheet (CSS) class name string that applies when the mouse hovers over the menu item. | ||
| - | ==== Id ==== | ||
| - | Gets the identifier of the context menu item. | ||
| - | ==== InnerHtml ==== | ||
| - | Gets or sets the content HTML of the context menu item. | ||
| - | ==== MenuItems ==== | ||
| - | Gets the menu item collection of the context menu item. | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection|GeoKeyedCollection]]<[[ThinkGeo.MapSuite.MvcEdition.ContextMenuItem|ContextMenuItem]]><!-- ThinkGeo.MapSuite.MvcEdition.GeoKeyedCollection{ThinkGeo.MapSuite.MvcEdition.ContextMenuItem} --> | | ||
| - | ==== OnClientClick ==== | ||
| - | Gets or sets the client-side script that executes when a context menu item's Click event is raised. | ||
| - | === Remarks === | ||
| - | There is a default parameter:e, which includes one parameter: "worldXY" | ||
| - | __NOTOC__ | ||
