thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting
thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting [2015/09/21 03:32]
-====== ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting ======
-A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view.
-  *System.Object
-    *ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null],​[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null]]
-      *ThinkGeo.MapSuite.MvcEdition.MarkerStyleSetting`2[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null],​[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting,​ MvcEdition, Version=9.0.0.0,​ Culture=neutral,​ PublicKeyToken=null]]
-        ***ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting**
-** {{wiki:​PublicMethod.gif|}} ClusterMarkerStyleSetting(ClusterMarkerStyle) **
-Initializes a new instance of the ClusterMarkerStyleSetting class.
-== Remarks ==
-N/A
-== Parameters ==
-  * //style//
-    * Type:​[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle|ClusterMarkerStyle]]
-    * Description:​the ClusterMarker Style which will be assigned to Element property
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} DistanceInPixel(Double) **
-Set distanceInPixel for Element property and retun the ClusterMarkerStyleSetting
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting|ClusterMarkerStyleSetting]]
-  * Description:​The setting of ClusterMarkerStyleSetting itself
-== Parameters ==
-  * //​distanceInPixel//​
-    * Type:Double
-    * Description:​A distanceInPixel for Element property
-** {{wiki:​PublicMethod.gif|}} MarkerStyle(Action<​MarkerStyleCollection>​) **
-Set MarkerStyle for Element property according to a method that takes MarkerStyleCollection and retun the ClusterMarkerStyleSetting
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​actionMarkerStyle//​
-    * Type:​Action<​[[ThinkGeo.MapSuite.MvcEdition.MarkerStyleCollection|MarkerStyleCollection]]>​
-    * Description:​a method that takes MarkerStyleCollection
-** {{wiki:​PublicMethod.gif|}} MapWidth(Double) **
-Set mapWidth for Element property and retun the ClusterMarkerStyleSetting
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​mapWidth//​
-    * Type:Double
-    * Description:​A mapWidth for Element property
-** {{wiki:​PublicMethod.gif|}} MapHeight(Double) **
-Set mapHeight for Element property and retun the ClusterMarkerStyleSetting
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-  * //​mapHeight//​
-    * Type:Double
-    * Description:​A mapHeight for Element property
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-  * Description:​N/​A
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​ProtectedProperty.gif|}} Element **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting.1442806355.txt.gz ยท Last modified: 2015/09/21 03:32 by admin
