thinkgeo.mapsuite.mvcedition.clustermarkerstylesetting [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting ====== | ||
| - | <!-- Class --> | ||
| - | A setting for ClusterMarkerStyle that contains APIs to set properties of ClusterMarkerStyleSetting using in MVC view. | ||
| - | *System.Object | ||
| - | * PublicKeyToken=null]] | ||
| - | * Culture=neutral | ||
| - | * Version=9.0.0.0 | ||
| - | ***** MvcEdition | ||
| - | ******[[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting]] | ||
| - | ******* PublicKeyToken=null] | ||
| - | ******** Culture=neutral | ||
| - | ********* Version=9.0.0.0 | ||
| - | ********** MvcEdition | ||
| - | ***********[[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase`2[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle]] | ||
| - | ************ PublicKeyToken=null]] | ||
| - | ************* Culture=neutral | ||
| - | ************** Version=9.0.0.0 | ||
| - | *************** MvcEdition | ||
| - | ****************[[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting]] | ||
| - | ***************** PublicKeyToken=null] | ||
| - | ****************** Culture=neutral | ||
| - | ******************* Version=9.0.0.0 | ||
| - | ******************** MvcEdition | ||
| - | *********************[[ThinkGeo.MapSuite.MvcEdition.MarkerStyleSetting`2[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle]] | ||
| - | **********************[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ClusterMarkerStyleSetting(ClusterMarkerStyle)|ClusterMarkerStyleSetting]] | [[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle|ClusterMarkerStyle]] | | Initializes a new instance of the ClusterMarkerStyleSetting class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#DistanceInPixel(Double)|DistanceInPixel]] | Double | | Set distanceInPixel for Element property and retun the ClusterMarkerStyleSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MapHeight(Double)|MapHeight]] | Double | | Set mapHeight for Element property and retun the ClusterMarkerStyleSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MapWidth(Double)|MapWidth]] | Double | | Set mapWidth for Element property and retun the ClusterMarkerStyleSetting | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MarkerStyle(Action<MarkerStyleCollection>)|MarkerStyle]] | Action<[[ThinkGeo.MapSuite.MvcEdition.MarkerStyleCollection|MarkerStyleCollection]]> | | Set MarkerStyle for Element property according to a method that takes MarkerStyleCollection and retun the ClusterMarkerStyleSetting | | ||
| - | | {{wiki:ProtectedProperty.gif|Protected Property}}[[#Element|Element]] | [[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle|ClusterMarkerStyle]] | [[ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase|MvcElementSettingBase]]<[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle|ClusterMarkerStyle]],[[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting|ClusterMarkerStyleSetting]]> | | | ||
| - | ==== ClusterMarkerStyleSetting(ClusterMarkerStyle) ==== | ||
| - | Initializes a new instance of the ClusterMarkerStyleSetting class. | ||
| - | === Parameters === | ||
| - | | style | [[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle|ClusterMarkerStyle]]<!-- ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle --> | the ClusterMarker Style which will be assigned to Element property | | ||
| - | ==== DistanceInPixel(Double) ==== | ||
| - | Set distanceInPixel for Element property and retun the ClusterMarkerStyleSetting | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting|ClusterMarkerStyleSetting]]<!-- ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting --> | The setting of ClusterMarkerStyleSetting itself | | ||
| - | | distanceInPixel | Double<!-- System.Double --> | A distanceInPixel for Element property | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting --> | ||
| - | ==== MapHeight(Double) ==== | ||
| - | Set mapHeight for Element property and retun the ClusterMarkerStyleSetting | ||
| - | | mapHeight | Double<!-- System.Double --> | A mapHeight for Element property | | ||
| - | ==== MapWidth(Double) ==== | ||
| - | Set mapWidth for Element property and retun the ClusterMarkerStyleSetting | ||
| - | | mapWidth | Double<!-- System.Double --> | A mapWidth for Element property | | ||
| - | ==== MarkerStyle(Action<MarkerStyleCollection>) ==== | ||
| - | Set MarkerStyle for Element property according to a method that takes MarkerStyleCollection and retun the ClusterMarkerStyleSetting | ||
| - | | actionMarkerStyle | Action<[[ThinkGeo.MapSuite.MvcEdition.MarkerStyleCollection|MarkerStyleCollection]]><!-- System.Action{ThinkGeo.MapSuite.MvcEdition.MarkerStyleCollection} --> | a method that takes MarkerStyleCollection | | ||
| - | ==== Element ==== | ||
| - | ^ Return Type ^ | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle|ClusterMarkerStyle]]<!-- ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle --> | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MvcElementSettingBase{ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyle,ThinkGeo.MapSuite.MvcEdition.ClusterMarkerStyleSetting} --> | ||
| - | [[#Protected Properties|Go Back]] | ||
| - | __NOTOC__ | ||
