thinkgeo.mapsuite.mvcedition.cloudpopup
thinkgeo.mapsuite.mvcedition.cloudpopup [2015/09/22 08:33]
-====== ThinkGeo.MapSuite.MvcEdition.CloudPopup ======
-Represents the popups that appear in a cloud (a.k.a. balloon) shape.
-  *System.Object
-    *ThinkGeo.MapSuite.MvcEdition.Popup
-      ***ThinkGeo.MapSuite.MvcEdition.CloudPopup**
-** {{wiki:​PublicMethod.gif|}} CloudPopup() **
-  * //​Initialize an instance of the CloudPopup class.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} CloudPopup(String) **
-  * //​Initialize an instance of the CloudPopup class with an Id string.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //id//
-    * Type:String
-    * Description:​The identifier by which you can find the popup.
-** {{wiki:​PublicMethod.gif|}} CloudPopup(String,​PointShape) **
-  * //​Initialize an instance of the CloudPopup class with an Id string and the position.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-    * Type:​[[ThinkGeo.MapSuite.Core.PointShape|PointShape]]
-    * Description:​A point shape in world coordinates that indicates the position of the popup.
-** {{wiki:​PublicMethod.gif|}} CloudPopup(String,​PointShape,​String) **
-  * //​Initialize an instance of the CloudPopup class with an Id string, position and the content of the popup.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-  * //​contentHtml//​
-    * Type:String
-    * Description:​An HTML string rendered as the popup content.
-** {{wiki:​PublicMethod.gif|}} CloudPopup(String,​PointShape,​String,​Int32,​Int32) **
-  * //​Initialize an instance of the CloudPopup class with Id string, position, popup content and size.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-    * Type:String
-  * //width//
-    * Type:Int32
-    * Description:​An int value that indicates the popup'​s width.
-  * //height//
-    * Type:Int32
-    * Description:​An int value that indicates the popup'​s height.
-** {{wiki:​PublicMethod.gif|}} CloudPopup(String,​PointShape,​String,​Int32,​Int32,​Boolean) **
-  * //​Initialize an instance of the CloudPopup class with an Id string, position, popup content, popup size and a boolean value that determines whether to pan the map if necessary to show the full popup.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-    * Type:String
-  * //width//
-    * Type:Int32
-  * //height//
-    * Type:Int32
-  * //autoPan//
-    * Type:​Boolean
-    * Description:​A boolean value indicating whether to pan the map if necessary to show the full popup.
-** {{wiki:​PublicMethod.gif|}} CloudPopup(String,​PointShape,​String,​Int32,​Int32,​Boolean,​Boolean) **
-  * //​Initialize an instance of the CloudPopup class with an Id string, position, popup'​s content, popup size, a boolean value for whether to pan the map to show the popup, and a boolean value for whether to have a close button on the popup.//
-== Remarks ==
-  * //N/A//
-== Parameters ==
-  * //id//
-    * Type:String
-  * //​position//​
-    * Type:String
-  * //width//
-    * Type:Int32
-  * //height//
-    * Type:Int32
-  * //autoPan//
-    * Type:​Boolean
-  * //​hasCloseButton//​
-    * Type:​Boolean
-    * Description:​A boolean value indicating whether the popup should have a close button.
-** {{wiki:​PublicMethod.gif|}} CloneShallow() **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.MvcEdition.Popup|Popup]]
-  * Description:​N/​A
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} ToJson() **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:String
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} FromJson(String) **
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​jsonString//​
-    * Type:String
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:String
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Type
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //N/A//
-== Remarks ==
-  * //N/A//
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} ContentHtml **
-Gets or sets the content HTML of the popup window.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Id **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} Position **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-** {{wiki:​PublicProperty.gif|}} Width **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} Height **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} IsVisible **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} Opacity **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Single
-** {{wiki:​PublicProperty.gif|}} AutoSize **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} AutoPan **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} HasCloseButton **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-** {{wiki:​PublicProperty.gif|}} OffsetXInPixels **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} OffsetYInPixels **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​ProtectedProperty.gif|}} PopupType **
-Gets a string that represents the type of the Popup object.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
thinkgeo.mapsuite.mvcedition.cloudpopup.1442910819.txt.gz ยท Last modified: 2015/09/22 08:33 by admin
