thinkgeo.mapsuite.mvcedition.arcgisserverrestoverlay [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlay ====== | ||
| - | <!-- Class --> | ||
| - | This class is used to display data from ArcGIS Server 9.3 (and up) Mapping Services using the REST API. More detail on the REST API is available at http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/index.html ;specifically, the URL provided to this layer should be an export service URL: http://sampleserver1.arcgisonline.com/ArcGIS/SDK/REST/export.html | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.MvcEdition.Overlay]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlay]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ArcGISServerRestOverlay()|ArcGISServerRestOverlay]] | | | Initialize an instance of the ArcGISServerRestOverlay class with none parameter. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ArcGISServerRestOverlay(String)|ArcGISServerRestOverlay]] | String | | Initialize an instance of the ArcGISServerRestOverlay class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ArcGISServerRestOverlay(String, Uri)|ArcGISServerRestOverlay]] | String, Uri | | Initialize an instance of the ArcGISServerRestOverlay class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ArcGISServerRestOverlay(Uri)|ArcGISServerRestOverlay]] | Uri | | Initialize an instance of the ArcGISServerRestOverlay class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ArcGISServerRestOverlay(String, Uri, TileType)|ArcGISServerRestOverlay]] | String, Uri, [[ThinkGeo.MapSuite.MvcEdition.TileType|TileType]] | | Initialize an instance of the ArcGISServerRestOverlay class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FromJson(String)|FromJson]] | String | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]](overriden) | Load this object from a json string. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Returns a JSON string which contains the information for creating an overlay at the client side. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#RegisterJavaScriptLibraryCore(Page)|RegisterJavaScriptLibraryCore]] | Page | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Registers a Javascript library URL string to the client HTML page. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Attribution|Attribution]] | String | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#AutoRefreshInterval|AutoRefreshInterval]] | TimeSpan | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets or sets the time interval in which the MarkerOverlay refreshes itself. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Id|Id]] | String | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets the identifier for the overlay to be found. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#IsBaseOverlay|IsBaseOverlay]] | Boolean | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets or sets a value that indicates whether the overlay is a base overlay. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#IsVisible|IsVisible]] | Boolean | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets or sets a value that indicates whether the overlay is visible on the map. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#IsVisibleInOverlaySwitcher|IsVisibleInOverlaySwitcher]] | Boolean | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Name|Name]] | String | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#OnClientAutoRefreshTick|OnClientAutoRefreshTick]] | String | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]](overriden) | Don't support auto tick event by default. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Opacity|Opacity]] | Single | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]] | Gets or sets the opacity level of the overlay. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Parameters|Parameters]] | Dictionary<String,String> | | Gets a dictionary whose items will be passed to the ArcGIS REST Server server as parameters. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Projection|Projection]] | String | | Gets or sets a string that will be sent to the ArcGIS REST server to get the images in the specific projection. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#ServerUri|ServerUri]] | Uri | | Gets or sets the URI that specifies the locations of the ArcGIS Rest servers. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TileHeight|TileHeight]] | Int32 | | Gets or sets the height of each tile, if the WmsOverlay uses tiling. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TileType|TileType]] | [[ThinkGeo.MapSuite.MvcEdition.TileType|TileType]] | | Gets or sets whether or not the ArcGISServerRestOverlay uses tiling. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TileWidth|TileWidth]] | Int32 | | Gets or sets the width of each tile, if the WmsOverlay uses tiling. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TransitionEffect|TransitionEffect]] | [[ThinkGeo.MapSuite.MvcEdition.TransitionEffect|TransitionEffect]] | | Gets or sets the transition effect to use when the map is zoomed. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TransitionEffectDelayInMilliseconds|TransitionEffectDelayInMilliseconds]] | Int32 | | | | ||
| - | | {{wiki:ProtectedProperty.gif|Protected Property}}[[#OverlayType|OverlayType]] | String | [[ThinkGeo.MapSuite.MvcEdition.Overlay|Overlay]](overriden) | Gets a string that indicates the overlay type. | | ||
| - | ==== ArcGISServerRestOverlay() ==== | ||
| - | Initialize an instance of the ArcGISServerRestOverlay class with none parameter. | ||
| - | === Parameters === | ||
| - | ==== ArcGISServerRestOverlay(String) ==== | ||
| - | Initialize an instance of the ArcGISServerRestOverlay class. | ||
| - | | id | String<!-- System.String --> | The identifier string of the ArcGISServerRestOverlay. | | ||
| - | ==== ArcGISServerRestOverlay(String, Uri) ==== | ||
| - | | serverUri | Uri<!-- System.Uri --> | The uri of the ArcGIS REST SERVER | | ||
| - | ==== ArcGISServerRestOverlay(Uri) ==== | ||
| - | ==== ArcGISServerRestOverlay(String, Uri, TileType) ==== | ||
| - | | tileType | [[ThinkGeo.MapSuite.MvcEdition.TileType|TileType]]<!-- ThinkGeo.MapSuite.MvcEdition.TileType --> | The Tile Type of the layer | | ||
| - | ==== FromJson(String) ==== | ||
| - | Load this object from a json string. | ||
| - | | jsonString | String<!-- System.String --> | a json string | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.Overlay(overriden) --> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string which contains the information for creating an overlay at the client side. | ||
| - | | String<!-- System.String --> | A JSON string which is used to create an overlay at the client side. | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.Overlay --> | ||
| - | ==== RegisterJavaScriptLibraryCore(Page) ==== | ||
| - | Registers a Javascript library URL string to the client HTML page. | ||
| - | === Remarks === | ||
| - | The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page. | ||
| - | | page | Page<!-- System.Web.UI.Page --> | The page object that is used for registering the javascript library. | | ||
| - | ==== Attribution ==== | ||
| - | ^ Return Type ^ | ||
| - | | String<!-- System.String --> | | ||
| - | ==== AutoRefreshInterval ==== | ||
| - | Gets or sets the time interval in which the MarkerOverlay refreshes itself. | ||
| - | | TimeSpan<!-- System.TimeSpan --> | | ||
| - | ==== Id ==== | ||
| - | Gets the identifier for the overlay to be found. | ||
| - | ==== IsBaseOverlay ==== | ||
| - | Gets or sets a value that indicates whether the overlay is a base overlay. | ||
| - | ==== IsVisible ==== | ||
| - | Gets or sets a value that indicates whether the overlay is visible on the map. | ||
| - | ==== IsVisibleInOverlaySwitcher ==== | ||
| - | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. | ||
| - | ==== Name ==== | ||
| - | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. | ||
| - | ==== OnClientAutoRefreshTick ==== | ||
| - | Don't support auto tick event by default. | ||
| - | ==== Opacity ==== | ||
| - | Gets or sets the opacity level of the overlay. | ||
| - | The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible. | ||
| - | | Single<!-- System.Single --> | | ||
| - | ==== Parameters ==== | ||
| - | Gets a dictionary whose items will be passed to the ArcGIS REST Server server as parameters. | ||
| - | | Dictionary<String,String><!-- System.Collections.Generic.Dictionary{System.String,System.String} --> | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.ArcGISServerRestOverlay --> | ||
| - | ==== Projection ==== | ||
| - | Gets or sets a string that will be sent to the ArcGIS REST server to get the images in the specific projection. | ||
| - | ==== ServerUri ==== | ||
| - | Gets or sets the URI that specifies the locations of the ArcGIS Rest servers. | ||
| - | | Uri<!-- System.Uri --> | | ||
| - | ==== TileHeight ==== | ||
| - | Gets or sets the height of each tile, if the WmsOverlay uses tiling. | ||
| - | | Int32<!-- System.Int32 --> | | ||
| - | ==== TileType ==== | ||
| - | Gets or sets whether or not the ArcGISServerRestOverlay uses tiling. | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.TileType|TileType]]<!-- ThinkGeo.MapSuite.MvcEdition.TileType --> | | ||
| - | ==== TileWidth ==== | ||
| - | Gets or sets the width of each tile, if the WmsOverlay uses tiling. | ||
| - | ==== TransitionEffect ==== | ||
| - | Gets or sets the transition effect to use when the map is zoomed. | ||
| - | | [[ThinkGeo.MapSuite.MvcEdition.TransitionEffect|TransitionEffect]]<!-- ThinkGeo.MapSuite.MvcEdition.TransitionEffect --> | | ||
| - | ==== TransitionEffectDelayInMilliseconds ==== | ||
| - | ==== OverlayType ==== | ||
| - | Gets a string that indicates the overlay type. | ||
| - | [[#Protected Properties|Go Back]] | ||
| - | __NOTOC__ | ||
