thinkgeo.mapsuite.mvcedition.animationpanmaptool [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool ====== | ||
| - | <!-- Class --> | ||
| - | Represents an animation pan tool which allows map pans to the position which users click using the transition effect. | ||
| - | === Remarks === | ||
| - | This map tools mainly caputure the click event on the map and then pan to the location clciked with the transition effect, also user could define the delay (in milliseconds) of the click event. | ||
| - | If user don't want this pan transition effect, and uesr could define his own client event using <strong>OnClick</strong> property. | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.MvcEdition.MapTool]] | ||
| - | ***[[ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#AnimationPanMapTool()|AnimationPanMapTool]] | | | Initialize an instance of the AnimationPanMapTool class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FromJson(String)|FromJson]] | String | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] | Load this object from a json string. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#ToJson()|ToJson]] | | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] | Returns a JSON string that represents the map control object. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Delay|Delay]] | Int32 | | The number of milliseconds between clicks before the event is considered a double-click. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Enabled|Enabled]] | Boolean | [[ThinkGeo.MapSuite.MvcEdition.MapTool|MapTool]] | Gets or sets a value that turns the feature on and off. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#OnClientClick|OnClientClick]] | String | | Gets or sets the client-side script that executes when you click on the map using this Animation Pan map tool. | | ||
| - | ==== AnimationPanMapTool() ==== | ||
| - | Initialize an instance of the AnimationPanMapTool class. | ||
| - | === Parameters === | ||
| - | ==== FromJson(String) ==== | ||
| - | Load this object from a json string. | ||
| - | | jsonString | String<!-- System.String --> | a json string | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.MapTool --> | ||
| - | ==== ToJson() ==== | ||
| - | Returns a JSON string that represents the map control object. | ||
| - | This method returns a JSON string that instructs the client Javascript to create a specific client object. | ||
| - | | String<!-- System.String --> | A JSON string that represents the map control. | | ||
| - | ==== Delay ==== | ||
| - | The number of milliseconds between clicks before the event is considered a double-click. | ||
| - | ^ Return Type ^ | ||
| - | | Int32<!-- System.Int32 --> | | ||
| - | <!-- ThinkGeo.MapSuite.MvcEdition.AnimationPanMapTool --> | ||
| - | ==== Enabled ==== | ||
| - | Gets or sets a value that turns the feature on and off. | ||
| - | ==== OnClientClick ==== | ||
| - | Gets or sets the client-side script that executes when you click on the map using this Animation Pan map tool. | ||
| - | There is a default parameter:e, which includes one parameter: "worldXY" | ||
| - | | String<!-- System.String --> | | ||
| - | __NOTOC__ | ||
