thinkgeo.mapsuite.mapsuitegeocoder.usageocoder [2015/09/22 08:32] admin |
| - | ====== ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder ====== | ||
| - | This class is for United States Geocoding. | ||
| - | *System.Object | ||
| - | *ThinkGeo.MapSuite.MapSuiteGeocoder.Geocoder | ||
| - | ***ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder** | ||
| - | ** {{wiki:PublicMethod.gif|}} UsaGeocoder() ** | ||
| - | * //This is the constructor of this class.// | ||
| - | == Remarks == | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28.29// | ||
| - | == Parameters == | ||
| - | ** {{wiki:PublicMethod.gif|}} UsaGeocoder(String) ** | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28String.29// | ||
| - | * //dataPath// | ||
| - | * Type:String | ||
| - | * Description:The path to the Geocoder data folder. | ||
| - | ** {{wiki:PublicMethod.gif|}} UsaGeocoder(String,MatchMode) ** | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28String.2C_MatchMode.29// | ||
| - | * //matchMode// | ||
| - | * Type:[[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchMode|MatchMode]] | ||
| - | * Description:This parameter represents the match mode. | ||
| - | ** {{wiki:PublicMethod.gif|}} UsaGeocoder(String,StreetNumberMatchingMode) ** | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28String.2C_StreetNumberMatchingMode.29// | ||
| - | * //streetNumberMatchingMode// | ||
| - | * Type:[[ThinkGeo.MapSuite.MapSuiteGeocoder.StreetNumberMatchingMode|StreetNumberMatchingMode]] | ||
| - | * Description:This parameter represents the street number match mode. | ||
| - | ** {{wiki:PublicMethod.gif|}} UsaGeocoder(String,MatchMode,StreetNumberMatchingMode) ** | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28String.2C_MatchMode.2C_StreetNumberMatchingMode.29// | ||
| - | ** {{wiki:PublicMethod.gif|}} Match(String,String) ** | ||
| - | * //This method matches the specified street address and zip code.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#Match.28String.2C_String.29// | ||
| - | == Return Value == | ||
| - | * Type:Collection<[[ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch|GeocoderMatch]]> | ||
| - | * Description:The matched results within a collection of GeocoderMatch. | ||
| - | * //streetAddress// | ||
| - | * Description:This parameter is the street address to match. | ||
| - | * //zip// | ||
| - | * Description:This parameter is the zip code to match. | ||
| - | ** {{wiki:PublicMethod.gif|}} Match(String,String,String) ** | ||
| - | * //This method matches the specified street address, city and state.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#Match.28String.2C_String.2C_String.29// | ||
| - | * //city// | ||
| - | * Description:This parameter is the city to match. | ||
| - | * //state// | ||
| - | * Description:This parameter is the state to match. | ||
| - | ** {{wiki:PublicMethod.gif|}} Open() ** | ||
| - | * //This method opens the Geocoder so that it is initialized and ready to use.// | ||
| - | * //This method is the concrete wrapper for the virtual method OpenCore.// | ||
| - | * Type:Void | ||
| - | * Description:N/A | ||
| - | ** {{wiki:PublicMethod.gif|}} Close() ** | ||
| - | * //This method closes the Geocoder and releases all of its resources.// | ||
| - | * //This method is the concrete wrapper for the virtual method CloseCore.// | ||
| - | ** {{wiki:PublicMethod.gif|}} Match(String) ** | ||
| - | * //This method matches the input source text.// | ||
| - | * //This method is the concrete wrapper for the virtual method MatchCore.// | ||
| - | * Description:A collection of GeocoderMatch. | ||
| - | * //sourceText// | ||
| - | * Description:Source text to match. | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#ToString.28.29// | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#Equals.28Object.29// | ||
| - | * Type:Boolean | ||
| - | * //obj// | ||
| - | * Type:Object | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#GetHashCode.28.29// | ||
| - | * Type:Int32 | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#GetType.28.29// | ||
| - | * Type:Type | ||
| - | ** {{wiki:ProtectedMethod.gif|}} OpenCore() ** | ||
| - | * //Opens all of the internal MatchingPlugins.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#OpenCore.28.29// | ||
| - | ** {{wiki:ProtectedMethod.gif|}} MatchCore(String) ** | ||
| - | * //This method matches the source text.// | ||
| - | * //This method calls the match method of each MatchingPlugIn object and then evaluates the match results from each MatchingPlugIn object to get the best match items.// | ||
| - | * Description:The source text to match. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} EvaluateMatchResults(IEnumerable<GeocoderMatch>) ** | ||
| - | * //This method evaluates the MatchItems from different MatchingPlugIns and gets the final MatchResult. This is a concrete wrapper for EvaluateMatchResultsCore.// | ||
| - | * //For the most updated Info for this topic, please check it here:// | ||
| - | * Description:The evaluated results within a collection of GeocoderMatch. | ||
| - | * //sourceMatchItems// | ||
| - | * Type:IEnumerable<[[ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch|GeocoderMatch]]> | ||
| - | * Description:The collection of GeocoderMatch. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} EvaluateMatchResultsCore(IEnumerable<GeocoderMatch>) ** | ||
| - | * //This method evaluates the MatchItems from different MatchingPlugIns and gets the final MatchResult. This method adds all MatchItems into one list, then loops though and evaluates every two MatchItems, sorts the MatchItems by the MatchRanking property of the MatchItem, and finally adds them to MatchResult. When evaluating two MatchItems, if the name-value pairs of the two MatchItems have the same key and that key is in the compare key array, just compare the value. If the values are equal then use the MatchRanking plus the RankingMultiplier.// | ||
| - | * Description:MatchResult object. | ||
| - | * Description:The collection of MatchItems. | ||
| - | ** {{wiki:ProtectedMethod.gif|}} CloseCore() ** | ||
| - | * //This method closes the Geocoder and releases all of its resources. This method loops through each MatchingPlugIn object in the MatchingPlugIns collection to call their Close() method.// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#CloseCore.28.29// | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#Finalize.28.29// | ||
| - | * //N/A// | ||
| - | * //For the most updated Info for this topic, please check it here:http:wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#MemberwiseClone.28.29// | ||
| - | ** {{wiki:PublicProperty.gif|}} MatchMode ** | ||
| - | This parameter represents the match mode. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28String.2C_MatchMode.29 | ||
| - | ** {{wiki:PublicProperty.gif|}} StreetNumberMatchingMode ** | ||
| - | This parameter represents the street number matching mode mode. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#UsaGeocoder.28String.2C_StreetNumberMatchingMode.29 | ||
| - | ** {{wiki:PublicProperty.gif|}} DataPath ** | ||
| - | The path to the Geocoder data folder. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#DataPath | ||
| - | ** {{wiki:PublicProperty.gif|}} MatchingPlugIns ** | ||
| - | The collection of MatchingPlugIns. | ||
| - | For the most updated Info for this topic, please check it here:http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.UsaGeocoder#MatchingPlugIns | ||
| - | * Type:Collection<[[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]]> | ||
