thinkgeo.mapsuite.mapsuitegeocoder.soundexdbfmatchingplugin
thinkgeo.mapsuite.mapsuitegeocoder.soundexdbfmatchingplugin [2015/09/21 07:04]
-====== ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin ======
-This class implements soundex matching operations. There are two columns in the DBF file that are necessary for soundex matching. The first is the soundex value generated by certain Soundex algorithms (by default this is implemented by SimplifiedSoundex). The second is the exact value.
-  *System.Object
-    *ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin
-      *ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin
-        ***ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin**
-** {{wiki:​PublicMethod.gif|}} SoundexDbfMatchingPlugin() **
-This is the constructor of this class.
-== Remarks ==
-N/A
-== Parameters ==
-<div newline></​div>​
-** {{wiki:​PublicMethod.gif|}} SoundexDbfMatchingPlugin(String,​String) **
-== Remarks ==
-N/A
-== Parameters ==
-  * //​pathFileName//​
-    * Type:String
-    * Description:​This parameter is path and file name of the index.
-  * //​soundexRealValueColumnName//​
-    * Type:String
-    * Description:​This parameter is the column name for the real value.
-** {{wiki:​PublicMethod.gif|}} GetRecord(Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Dictionary<​String,​String>​
-  * Description:​N/​A
-== Parameters ==
-  * //​recordNumber//​
-    * Type:Int32
-** {{wiki:​PublicMethod.gif|}} GetRecords(Int32,​Int32) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Collection<​Dictionary<​String,​String>>​
-== Parameters ==
-  * //​firstRecordNumber//​
-    * Type:Int32
-  * //count//
-    * Type:Int32
-** {{wiki:​PublicMethod.gif|}} AddRecord(IEnumerable<​Object>​) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //values//
-    * Type:​IEnumerable<​Object>​
-** {{wiki:​PublicMethod.gif|}} Dispose() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} Match(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Collection<​[[ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch|GeocoderMatch]]>​
-== Parameters ==
-  * //​sourceText//​
-    * Type:String
-** {{wiki:​PublicMethod.gif|}} Open() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​PublicMethod.gif|}} Close() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Boolean
-== Parameters ==
-  * //obj//
-    * Type:Object
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Type
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} MatchCore(String) **
-This method matches source text in corresponding index files. This function tries to get all MatchItems by using binary searching in MatchDbf, but there could be many inaccurate results returned because of Soundex. Thus, it loops through each MatchItem, calculates the ditance between the result and the source according to the Levenshteins algorithm, then finds the result with the shortest distance.
-== Remarks ==
-N/A
-== Return Value ==
-  * Description:​The collection of MatchItem objects.
-== Parameters ==
-    * Type:String
-    * Description:​The source text to match.
-** {{wiki:​ProtectedMethod.gif|}} OpenCore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} CloseCore() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} SearchUpperBound(Int32,​Int32,​String,​String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-    * Type:Int32
-  * //​lastRecordNumber//​
-    * Type:Int32
-    * Type:String
-  * //​columnName//​
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} SearchLowerBound(Int32,​Int32,​String,​String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-== Parameters ==
-    * Type:Int32
-    * Type:Int32
-    * Type:String
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} GetKeyColumnName() **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} BinarySearch(Int32,​Int32,​String,​String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-    * Type:Int32
-    * Type:Int32
-    * Type:String
-    * Type:String
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-** {{wiki:​ProtectedMethod.gif|}} Formalize(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​Collection<​String>​
-== Parameters ==
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} FormalizeCore(String) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-== Parameters ==
-    * Type:String
-** {{wiki:​ProtectedMethod.gif|}} oxM=(GeocoderMatch) **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Void
-== Parameters ==
-  * //​geocoderMatch//​
-    * Type:​[[ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch|GeocoderMatch]]
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Object
-== Parameters ==
-** {{wiki:​PublicProperty.gif|}} SoundexRealValueColumnName **
-This property is the column name for the real value.
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} PathFileName **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:String
-** {{wiki:​PublicProperty.gif|}} ReadWriteMode **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:​[[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginReadWriteMode|DbfMatchingPluginReadWriteMode]]
-** {{wiki:​PublicProperty.gif|}} RecordCount **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
-** {{wiki:​PublicProperty.gif|}} RankingMultiplier **
-N/A
-== Remarks ==
-N/A
-== Return Value ==
-  * Type:Int32
thinkgeo.mapsuite.mapsuitegeocoder.soundexdbfmatchingplugin.1442819040.txt.gz ยท Last modified: 2015/09/21 07:04 by admin
