thinkgeo.mapsuite.mapsuitegeocoder.soundexdbfmatchingplugin [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin ====== | ||
| - | <!-- Class --> | ||
| - | This class implements soundex matching operations. There are two columns in the DBF file that are necessary for soundex matching. The first is the soundex value generated by certain Soundex algorithms (by default this is implemented by SimplifiedSoundex). The second is the exact value. | ||
| - | === Remarks === | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin</a> | ||
| - | *System.Object | ||
| - | **[[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin]] | ||
| - | ***[[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin]] | ||
| - | ****[[ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#SoundexDbfMatchingPlugin()|SoundexDbfMatchingPlugin]] | | | This is the constructor of this class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#SoundexDbfMatchingPlugin(String, String)|SoundexDbfMatchingPlugin]] | String, String | | This is the constructor of this class. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#AddRecord(IEnumerable<Object>)|AddRecord]] | IEnumerable<Object> | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method adds one record to the DBF file. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Close()|Close]] | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]] | This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}{{wiki:Static.gif|Static Member}}[[#CreateDbf(String, IEnumerable<DbfMatchingPluginColumn>)|CreateDbf]] | String, IEnumerable<[[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn|DbfMatchingPluginColumn]]> | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method creates a DBF file according to the specified file name and column names. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Dispose()|Dispose]] | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | Releases all resources used by the DbfMatchingPlugin. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#GetRecord(Int32)|GetRecord]] | Int32 | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method gets a record by record index from the DBF file. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#GetRecords(Int32, Int32)|GetRecords]] | Int32, Int32 | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method gets records by using the specified range. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Match(String)|Match]] | String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]] | This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#Open()|Open]] | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]] | This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#BinarySearch(Int32, Int32, String, String)|BinarySearch]] | Int32, Int32, String, String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method does a binary search on the DBF file and returns the record it hits. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#CloseCore()|CloseCore]] | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]](overriden) | | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Finalize()|Finalize]] | | Object(overriden) | | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#Formalize(String)|Formalize]] | String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]] | This method formalizes the source text. This method is the concrete wrapper of FormalizeCore. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#FormalizeCore(String)|FormalizeCore]] | String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]] | This method formalizes the source text. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#GetKeyColumnName()|GetKeyColumnName]] | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method gets the key column name from the DBF file. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#MatchCore(String)|MatchCore]] | String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]](overriden) | This method matches source text in corresponding index files. This function tries to get all MatchItems by using binary searching in MatchDbf, but there could be many inaccurate results returned because of Soundex. Thus, it loops through each MatchItem, calculates the ditance between the result and the source according to the Levenshteins algorithm, then finds the result with the shortest distance. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#OpenCore()|OpenCore]] | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]](overriden) | | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#SearchLowerBound(Int32, Int32, String, String)|SearchLowerBound]] | Int32, Int32, String, String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method gets the record number of the lower boundary of the matched results. | | ||
| - | | {{wiki:ProtectedMethod.gif|Protected Method}}[[#SearchUpperBound(Int32, Int32, String, String)|SearchUpperBound]] | Int32, Int32, String, String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This method gets the record number of the upper boundary of the matched results. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#PathFileName|PathFileName]] | String | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | Gets and sets the path and file name of the DBF file to be used for Geocoding. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#RankingMultiplier|RankingMultiplier]] | Int32 | [[ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin|MatchingPlugin]] | This property is the ranking multipier for GeocoderMatch. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#ReadWriteMode|ReadWriteMode]] | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginReadWriteMode|DbfMatchingPluginReadWriteMode]] | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | The read/write mode for the DBF file. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#RecordCount|RecordCount]] | Int32 | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin|DbfMatchingPlugin]] | This record count of the DBF file. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#SoundexRealValueColumnName|SoundexRealValueColumnName]] | String | | This property is the column name for the real value. | | ||
| - | ==== SoundexDbfMatchingPlugin() ==== | ||
| - | This is the constructor of this class. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexDbfMatchingPlugin.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexDbfMatchingPlugin.28.29</a> | ||
| - | === Parameters === | ||
| - | ==== SoundexDbfMatchingPlugin(String, String) ==== | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexDbfMatchingPlugin.28String.2C_String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexDbfMatchingPlugin.28String.2C_String.29</a> | ||
| - | | pathFileName | String<!-- System.String --> | This parameter is path and file name of the index. | | ||
| - | | soundexRealValueColumnName | String<!-- System.String --> | This parameter is the column name for the real value. | | ||
| - | ==== AddRecord(IEnumerable<Object>) ==== | ||
| - | This method adds one record to the DBF file. | ||
| - | For the most updated Info for this topic, please check it here:<a href="" target="_blank"></a> | ||
| - | | values | IEnumerable<Object><!-- System.Collections.Generic.IEnumerable{System.Object} --> | This parameter represents a record in the DBF file. | | ||
| - | <!-- ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPlugin --> | ||
| - | ==== Close() ==== | ||
| - | This method closes the MatchingPlugin. This method is the concrete wrapper for CloseCore. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Close.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Close.28.29</a> | ||
| - | <!-- ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin --> | ||
| - | ==== CreateDbf(String, IEnumerable<DbfMatchingPluginColumn>) ==== | ||
| - | <!-- static --> | ||
| - | This method creates a DBF file according to the specified file name and column names. | ||
| - | | Void<!-- System.Void --> | The newly-created DbfMatchingPlugIn object. | | ||
| - | | pathFileName | String<!-- System.String --> | This parameter is the path and file name of the DBF file. | | ||
| - | | columnNames | IEnumerable<[[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn|DbfMatchingPluginColumn]]><!-- System.Collections.Generic.IEnumerable{ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginColumn} --> | This parameter is the collection of DbfColumnDefinition objects. | | ||
| - | ==== Dispose() ==== | ||
| - | Releases all resources used by the DbfMatchingPlugin. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Dispose.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Dispose.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Equals.28Object.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Equals.28Object.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetHashCode.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetHashCode.28.29</a> | ||
| - | ==== GetRecord(Int32) ==== | ||
| - | This method gets a record by record index from the DBF file. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetRecord.28Int32.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetRecord.28Int32.29</a> | ||
| - | | Dictionary<String,String><!-- System.Collections.Generic.Dictionary{System.String,System.String} --> | The record value. | | ||
| - | | recordNumber | Int32<!-- System.Int32 --> | This parameter is the record number. | | ||
| - | ==== GetRecords(Int32, Int32) ==== | ||
| - | This method gets records by using the specified range. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetRecords.28Int32.2C_Int32.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetRecords.28Int32.2C_Int32.29</a> | ||
| - | | Collection<Dictionary<String,String>><!-- System.Collections.ObjectModel.Collection{System.Collections.Generic.Dictionary{System.String,System.String}} --> | The collection of record values. | | ||
| - | | firstRecordNumber | Int32<!-- System.Int32 --> | This parameter is the first record number to get. | | ||
| - | | count | Int32<!-- System.Int32 --> | This parameter is the record count to return. | | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetType.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetType.28.29</a> | ||
| - | ==== Match(String) ==== | ||
| - | This method matches the source text and returns a collection of GeocoderMatch. This method is the concrete wrapper for MatchCore. It firstly formalizes the input sourceText, gets the formalized results and matches them using MatchCore one by one, then returns all of the results within a collection. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Match.28String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Match.28String.29</a> | ||
| - | | Collection<[[ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch|GeocoderMatch]]><!-- System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} --> | A collection of GeocoderMatch. | | ||
| - | | sourceText | String<!-- System.String --> | The source text to match. | | ||
| - | ==== Open() ==== | ||
| - | This method opens the MatchingPlugin for use. This method is the concrete wrapper for OpenCore. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Open.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Open.28.29</a> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#ToString.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#ToString.28.29</a> | ||
| - | ==== BinarySearch(Int32, Int32, String, String) ==== | ||
| - | This method does a binary search on the DBF file and returns the record it hits. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#BinarySearch.28Int32.2C_Int32.2C_String.2C_String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#BinarySearch.28Int32.2C_Int32.2C_String.2C_String.29</a> | ||
| - | | Dictionary<String,String><!-- System.Collections.Generic.Dictionary{System.String,System.String} --> | The record hits in the search. | | ||
| - | | firstRecordNumber | Int32<!-- System.Int32 --> | The first record number for the search. | | ||
| - | | lastRecordNumber | Int32<!-- System.Int32 --> | The last record number for the search. | | ||
| - | | columnName | String<!-- System.String --> | The name of the column on which the binaray search is based. | | ||
| - | ==== CloseCore() ==== | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#CloseCore.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#CloseCore.28.29</a> | ||
| - | <!-- ThinkGeo.MapSuite.MapSuiteGeocoder.MatchingPlugin(overriden) --> | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Finalize.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Finalize.28.29</a> | ||
| - | <!-- System.Object(overriden) --> | ||
| - | ==== Formalize(String) ==== | ||
| - | This method formalizes the source text. This method is the concrete wrapper of FormalizeCore. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Formalize.28String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#Formalize.28String.29</a> | ||
| - | | Collection<String><!-- System.Collections.ObjectModel.Collection{System.String} --> | The collection of formalized strings. | | ||
| - | | sourceText | String<!-- System.String --> | The source text to formalize. | | ||
| - | ==== FormalizeCore(String) ==== | ||
| - | This method formalizes the source text. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#FormalizeCore.28String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#FormalizeCore.28String.29</a> | ||
| - | ==== GetKeyColumnName() ==== | ||
| - | This method gets the key column name from the DBF file. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetKeyColumnName.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#GetKeyColumnName.28.29</a> | ||
| - | | String<!-- System.String --> | The key column name. | | ||
| - | ==== MatchCore(String) ==== | ||
| - | This method matches source text in corresponding index files. This function tries to get all MatchItems by using binary searching in MatchDbf, but there could be many inaccurate results returned because of Soundex. Thus, it loops through each MatchItem, calculates the ditance between the result and the source according to the Levenshteins algorithm, then finds the result with the shortest distance. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#MatchCore.28String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#MatchCore.28String.29</a> | ||
| - | | Collection<[[ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch|GeocoderMatch]]><!-- System.Collections.ObjectModel.Collection{ThinkGeo.MapSuite.MapSuiteGeocoder.GeocoderMatch} --> | The collection of MatchItem objects. | | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#MemberwiseClone.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#MemberwiseClone.28.29</a> | ||
| - | ==== OpenCore() ==== | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#OpenCore.28.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#OpenCore.28.29</a> | ||
| - | ==== SearchLowerBound(Int32, Int32, String, String) ==== | ||
| - | This method gets the record number of the lower boundary of the matched results. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SearchLowerBound.28Int32.2C_Int32.2C_String.2C_String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SearchLowerBound.28Int32.2C_Int32.2C_String.2C_String.29</a> | ||
| - | | Int32<!-- System.Int32 --> | The record number of the lower boundary of the matched results. | | ||
| - | | sourceText | String<!-- System.String --> | The source text to search for. | | ||
| - | | columnName | String<!-- System.String --> | The name of the column on which the search is based. | | ||
| - | ==== SearchUpperBound(Int32, Int32, String, String) ==== | ||
| - | This method gets the record number of the upper boundary of the matched results. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SearchUpperBound.28Int32.2C_Int32.2C_String.2C_String.29" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SearchUpperBound.28Int32.2C_Int32.2C_String.2C_String.29</a> | ||
| - | | Int32<!-- System.Int32 --> | The record number of the upper boundary of the matched results. | | ||
| - | ==== PathFileName ==== | ||
| - | Gets and sets the path and file name of the DBF file to be used for Geocoding. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#PathFileName" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#PathFileName</a> | ||
| - | ^ Return Type ^ | ||
| - | | String<!-- System.String --> | | ||
| - | ==== RankingMultiplier ==== | ||
| - | This property is the ranking multipier for GeocoderMatch. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#RankingMultiplier" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#RankingMultiplier</a> | ||
| - | | Int32<!-- System.Int32 --> | | ||
| - | ==== ReadWriteMode ==== | ||
| - | The read/write mode for the DBF file. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#ReadWriteMode" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#ReadWriteMode</a> | ||
| - | | [[ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginReadWriteMode|DbfMatchingPluginReadWriteMode]]<!-- ThinkGeo.MapSuite.MapSuiteGeocoder.DbfMatchingPluginReadWriteMode --> | | ||
| - | ==== RecordCount ==== | ||
| - | This record count of the DBF file. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#RecordCount" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#RecordCount</a> | ||
| - | ==== SoundexRealValueColumnName ==== | ||
| - | This property is the column name for the real value. | ||
| - | For the most updated Info for this topic, please check it here:<a href="http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexRealValueColumnName" target="_blank">http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin#SoundexRealValueColumnName</a> | ||
| - | <!-- ThinkGeo.MapSuite.MapSuiteGeocoder.SoundexDbfMatchingPlugin --> | ||
| - | __NOTOC__ | ||
| - | [[Category:MapSuiteGeocoder]] | ||
| - | [[Category:ThinkGeo.MapSuite.MapSuiteGeocoder]] | ||
