thinkgeo.mapsuite.iosedition.featuredraggingeditinteractiveoverlayeventargs
thinkgeo.mapsuite.iosedition.featuredraggingeditinteractiveoverlayeventargs [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.iOSEdition.FeatureDraggingEditInteractiveOverlayEventArgs ======
-<!-- Class -->
-Provides data for the FeatureDragging. event.
-*System.Object
-**System.EventArgs
-***[[ThinkGeo.MapSuite.iOSEdition.FeatureDraggingEditInteractiveOverlayEventArgs]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​FeatureDraggingEditInteractiveOverlayEventArgs()|FeatureDraggingEditInteractiveOverlayEventArgs]] ​  ​| ​   |    | This is the default constructor of this parameter. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​FeatureDraggingEditInteractiveOverlayEventArgs(Feature,​ Boolean, PointShape, PointShape)|FeatureDraggingEditInteractiveOverlayEventArgs]] ​  | [[ThinkGeo.MapSuite.Core.Feature|Feature]],​ Boolean, [[ThinkGeo.MapSuite.Core.PointShape|PointShape]],​ [[ThinkGeo.MapSuite.Core.PointShape|PointShape]] ​  ​| ​   | This is the commonly used constructor. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Cancel|Cancel]] ​  | Boolean ​  ​| ​   | This property gets or sets the action to be canceled or not.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​DraggingFeature|DraggingFeature]] ​  | [[ThinkGeo.MapSuite.Core.Feature|Feature]] ​  ​| ​   | This property gets or sets the Feature to be used to dragged. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​SourceControlPoint|SourceControlPoint]] ​  | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]] ​  ​| ​   | This property gets or sets the source control point to drag.   |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​TargetControlPoint|TargetControlPoint]] ​  | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]] ​  ​| ​   | This property gets or sets the target control point to drag.   |
-==== FeatureDraggingEditInteractiveOverlayEventArgs() ====
-=== Remarks ===
-=== Parameters ===
-==== FeatureDraggingEditInteractiveOverlayEventArgs(Feature,​ Boolean, PointShape, PointShape) ====
-=== Parameters ===
-| draggingFeature ​  | [[ThinkGeo.MapSuite.Core.Feature|Feature]]<​!-- ThinkGeo.MapSuite.Core.Feature --> ​  | This parameter specified the target feature to be dragged. ​  |
-| cancel ​  | Boolean<​!-- System.Boolean --> ​  | This parameter specified the cancel property. ​  |
-| sourceControlPoint ​  | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]]<​!-- ThinkGeo.MapSuite.Core.PointShape --> ​  | This parameter specified the source control point to be dragged. ​  |
-| targetControlPoint ​  | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]]<​!-- ThinkGeo.MapSuite.Core.PointShape --> ​  | This parameter specified the target control point to be dragged. ​  |
-===== Public Methods =====
-==== Equals(Object) ====
-=== Return Value ===
-=== Parameters ===
-<!-- System.Object -->
-[[#Public Methods|Go Back]]
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== Finalize() ====
-=== Parameters ===
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Cancel ====
-This property gets or sets the action to be canceled or not.
-^ Return Type ^
-<!-- ThinkGeo.MapSuite.iOSEdition.FeatureDraggingEditInteractiveOverlayEventArgs -->
-==== DraggingFeature ====
-This property gets or sets the Feature to be used to dragged.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.Core.Feature|Feature]]<​!-- ThinkGeo.MapSuite.Core.Feature --> ​  |
-==== SourceControlPoint ====
-This property gets or sets the source control point to drag.
-^ Return Type ^
-| [[ThinkGeo.MapSuite.Core.PointShape|PointShape]]<​!-- ThinkGeo.MapSuite.Core.PointShape --> ​  |
-==== TargetControlPoint ====
-This property gets or sets the target control point to drag.
-^ Return Type ^
-===== Public Events =====
-__NOTOC__
-[[Category:​iOSEdition]]
-[[Category:​ThinkGeo.MapSuite.iOSEdition]]
thinkgeo.mapsuite.iosedition.featuredraggingeditinteractiveoverlayeventargs.1440040131.txt.gz ยท Last modified: 2015/09/21 08:32 (external edit)
