thinkgeo.mapsuite.iosedition.cgnativeimage
thinkgeo.mapsuite.iosedition.cgnativeimage [2015/08/20 03:08]
-====== ThinkGeo.MapSuite.iOSEdition.CGNativeImage ======
-<!-- Class -->
-This class represents an NativeImage object for iOS platform.
-*System.Object
-**[[ThinkGeo.MapSuite.iOSEdition.CGNativeImage]]
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​CGNativeImage()|CGNativeImage]] ​  ​| ​   |    | Initializes a new instance of the class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​CGNativeImage(Single,​ Single)|CGNativeImage]] ​  | Single, Single ​  ​| ​   | Initializes a new instance of the class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​CGNativeImage(Stream)|CGNativeImage]] ​  | Stream ​  ​| ​   | Initializes a new instance of the class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​CGNativeImage(UIImage)|CGNativeImage]] ​  | UIImage ​  ​| ​   | Initializes a new instance of the class. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​BeginInit()|BeginInit]] ​  ​| ​   |    | Begins the initialize to draw image. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​Dispose()|Dispose]] ​  ​| ​   |    | Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources. ​  |
-| {{wiki:​PublicMethod.gif|Public Method}}[[#​EndInit()|EndInit]] ​  ​| ​   |    | Ends the initialize. ​  |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​BeginInitCore()|BeginInitCore]] ​  ​| ​   |    | Begins the initialize core to draw image. ​  |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​Dispose(Boolean)|Dispose]] ​  | Boolean ​  ​| ​   | Releases unmanaged and - optionally - managed resources. ​  |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​EndInitCore()|EndInitCore]] ​  ​| ​   |    | Ends the initialize core.   |
-| {{wiki:​ProtectedMethod.gif|Protected Method}}[[#​Finalize()|Finalize]] ​  ​| ​   | Object(overriden) ​  | Finalizes an instance of the class. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Context|Context]] ​  | CGContext ​  ​| ​   | Gets or sets the context. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Height|Height]] ​  | Single ​  ​| ​   | Gets or sets the height for NativeImage. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​UIImage|UIImage]] ​  | UIImage ​  ​| ​   | Gets or sets the UI image. ​  |
-| {{wiki:​PublicProperty.gif|Public Property}}[[#​Width|Width]] ​  | Single ​  ​| ​   | Gets or sets the width for NativeImage. ​  |
-==== CGNativeImage() ====
-Initializes a new instance of the class.
-=== Parameters ===
-==== CGNativeImage(Single,​ Single) ====
-=== Parameters ===
-| width   | Single<​!-- System.Single --> ​  | The width. ​  |
-| height ​  | Single<​!-- System.Single --> ​  | The height. ​  |
-==== CGNativeImage(Stream) ====
-=== Parameters ===
-| imageStream ​  | Stream<​!-- System.IO.Stream --> ​  | The image stream. ​  |
-==== CGNativeImage(UIImage) ====
-=== Parameters ===
-| uiImage ​  | UIImage<​!-- MonoTouch.UIKit.UIImage --> ​  | The UI image. ​  |
-===== Public Methods =====
-==== BeginInit() ====
-Begins the initialize to draw image.
-=== Return Value ===
-=== Parameters ===
-<!-- ThinkGeo.MapSuite.iOSEdition.CGNativeImage -->
-[[#Public Methods|Go Back]]
-==== Dispose() ====
-Performs application-defined tasks associated with freeing, releasing, or resetting unmanaged resources.
-=== Parameters ===
-==== EndInit() ====
-Ends the initialize.
-=== Parameters ===
-==== Equals(Object) ====
-=== Parameters ===
-<!-- System.Object -->
-==== GetHashCode() ====
-=== Parameters ===
-==== GetType() ====
-=== Parameters ===
-==== ToString() ====
-=== Parameters ===
-==== BeginInitCore() ====
-Begins the initialize core to draw image.
-=== Parameters ===
-==== Dispose(Boolean) ====
-Releases unmanaged and - optionally - managed resources.
-=== Parameters ===
-| p   | Boolean<​!-- System.Boolean --> ​  | true to release both managed and unmanaged resources; false to release only unmanaged resources. ​  |
-==== EndInitCore() ====
-Ends the initialize core.
-=== Parameters ===
-==== Finalize() ====
-Finalizes an instance of the class.
-=== Parameters ===
-<!-- System.Object(overriden) -->
-==== MemberwiseClone() ====
-=== Parameters ===
-==== Context ====
-Gets or sets the context.
-^ Return Type ^
-| CGContext<​!-- MonoTouch.CoreGraphics.CGContext --> ​  |
-==== Height ====
-Gets or sets the height for NativeImage.
-^ Return Type ^
-| Single<​!-- System.Single --> ​  |
-==== UIImage ====
-Gets or sets the UI image.
-^ Return Type ^
-| UIImage<​!-- MonoTouch.UIKit.UIImage --> ​  |
-==== Width ====
-Gets or sets the width for NativeImage.
-^ Return Type ^
-===== Public Events =====
-__NOTOC__
-[[Category:​iOSEdition]]
-[[Category:​ThinkGeo.MapSuite.iOSEdition]]
thinkgeo.mapsuite.iosedition.cgnativeimage.1440040131.txt.gz ยท Last modified: 2015/09/21 08:32 (external edit)
