thinkgeo.mapsuite.androidedition.mousemovedtrackinteractiveoverlayeventargs [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.AndroidEdition.MouseMovedTrackInteractiveOverlayEventArgs ====== | ||
| - | <!-- Class --> | ||
| - | Provides data for the MouseMoved. event. | ||
| - | *System.Object | ||
| - | **System.EventArgs | ||
| - | ***[[ThinkGeo.MapSuite.AndroidEdition.MouseMovedTrackInteractiveOverlayEventArgs]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MouseMovedTrackInteractiveOverlayEventArgs()|MouseMovedTrackInteractiveOverlayEventArgs]] | | | This is the default constructor of this parameter. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#MouseMovedTrackInteractiveOverlayEventArgs(Vertex, Feature)|MouseMovedTrackInteractiveOverlayEventArgs]] | [[ThinkGeo.MapSuite.Core.Vertex|Vertex]], [[ThinkGeo.MapSuite.Core.Feature|Feature]] | | This is the commonly used constructor. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#AffectedFeature|AffectedFeature]] | [[ThinkGeo.MapSuite.Core.Feature|Feature]] | | This property gets or sets the Feature to be affected. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#MovedVertex|MovedVertex]] | [[ThinkGeo.MapSuite.Core.Vertex|Vertex]] | | This property gets or sets the vertex to be moved. | | ||
| - | ==== MouseMovedTrackInteractiveOverlayEventArgs() ==== | ||
| - | This is the default constructor of this parameter. | ||
| - | === Remarks === | ||
| - | If you use this constructor, you have to set the properties manually before use. | ||
| - | === Parameters === | ||
| - | ==== MouseMovedTrackInteractiveOverlayEventArgs(Vertex, Feature) ==== | ||
| - | This is the commonly used constructor. | ||
| - | | movedVertex | [[ThinkGeo.MapSuite.Core.Vertex|Vertex]]<!-- ThinkGeo.MapSuite.Core.Vertex --> | This parameter specified the target vertex to be moved. | | ||
| - | | affectedFeature | [[ThinkGeo.MapSuite.Core.Feature|Feature]]<!-- ThinkGeo.MapSuite.Core.Feature --> | This parameter specified the affected feature. | | ||
| - | ==== AffectedFeature ==== | ||
| - | This property gets or sets the Feature to be affected. | ||
| - | ^ Return Type ^ | ||
| - | | [[ThinkGeo.MapSuite.Core.Feature|Feature]]<!-- ThinkGeo.MapSuite.Core.Feature --> | | ||
| - | <!-- ThinkGeo.MapSuite.AndroidEdition.MouseMovedTrackInteractiveOverlayEventArgs --> | ||
| - | ==== MovedVertex ==== | ||
| - | This property gets or sets the vertex to be moved. | ||
| - | | [[ThinkGeo.MapSuite.Core.Vertex|Vertex]]<!-- ThinkGeo.MapSuite.Core.Vertex --> | | ||
| - | __NOTOC__ | ||
| - | [[Category:AndroidEdition]] | ||
| - | [[Category:ThinkGeo.MapSuite.AndroidEdition]] | ||
