thinkgeo.mapsuite.androidedition.featurerotatingeditinteractiveoverlayeventargs [2015/08/20 03:08] 127.0.0.1 external edit |
| - | ====== ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs ====== | ||
| - | <!-- Class --> | ||
| - | Provides data for the FeatureRotating. event. | ||
| - | *System.Object | ||
| - | **System.EventArgs | ||
| - | ***[[ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs]] | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FeatureRotatingEditInteractiveOverlayEventArgs()|FeatureRotatingEditInteractiveOverlayEventArgs]] | | | This is the default constructor of this parameter. | | ||
| - | | {{wiki:PublicMethod.gif|Public Method}}[[#FeatureRotatingEditInteractiveOverlayEventArgs(Feature, Boolean, PointShape, PointShape)|FeatureRotatingEditInteractiveOverlayEventArgs]] | [[ThinkGeo.MapSuite.Core.Feature|Feature]], Boolean, [[ThinkGeo.MapSuite.Core.PointShape|PointShape]], [[ThinkGeo.MapSuite.Core.PointShape|PointShape]] | | This is the commonly used constructor. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#Cancel|Cancel]] | Boolean | | This property gets or sets the action to be canceled or not. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#RotatingFeature|RotatingFeature]] | [[ThinkGeo.MapSuite.Core.Feature|Feature]] | | This property gets or sets the Feature to be used to roated. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#SourceControlPoint|SourceControlPoint]] | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]] | | This property gets or sets the source control point to roate. | | ||
| - | | {{wiki:PublicProperty.gif|Public Property}}[[#TargetControlPoint|TargetControlPoint]] | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]] | | This property gets or sets the target control point to roate. | | ||
| - | ==== FeatureRotatingEditInteractiveOverlayEventArgs() ==== | ||
| - | This is the default constructor of this parameter. | ||
| - | === Remarks === | ||
| - | If you use this constructor, you have to set the properties manually before use. | ||
| - | === Parameters === | ||
| - | ==== FeatureRotatingEditInteractiveOverlayEventArgs(Feature, Boolean, PointShape, PointShape) ==== | ||
| - | This is the commonly used constructor. | ||
| - | | rotatingFeature | [[ThinkGeo.MapSuite.Core.Feature|Feature]]<!-- ThinkGeo.MapSuite.Core.Feature --> | This parameter specified the target feature to be rotated. | | ||
| - | | cancel | Boolean<!-- System.Boolean --> | This parameter specified the cancel property. | | ||
| - | | sourceControlPoint | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]]<!-- ThinkGeo.MapSuite.Core.PointShape --> | This parameter specified the source control point to be roated. | | ||
| - | | targetControlPoint | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]]<!-- ThinkGeo.MapSuite.Core.PointShape --> | This parameter specified the target control point to be roated. | | ||
| - | ==== Cancel ==== | ||
| - | This property gets or sets the action to be canceled or not. | ||
| - | ^ Return Type ^ | ||
| - | <!-- ThinkGeo.MapSuite.AndroidEdition.FeatureRotatingEditInteractiveOverlayEventArgs --> | ||
| - | ==== RotatingFeature ==== | ||
| - | This property gets or sets the Feature to be used to roated. | ||
| - | | [[ThinkGeo.MapSuite.Core.Feature|Feature]]<!-- ThinkGeo.MapSuite.Core.Feature --> | | ||
| - | ==== SourceControlPoint ==== | ||
| - | This property gets or sets the source control point to roate. | ||
| - | | [[ThinkGeo.MapSuite.Core.PointShape|PointShape]]<!-- ThinkGeo.MapSuite.Core.PointShape --> | | ||
| - | ==== TargetControlPoint ==== | ||
| - | This property gets or sets the target control point to roate. | ||
| - | __NOTOC__ | ||
| - | [[Category:AndroidEdition]] | ||
| - | [[Category:ThinkGeo.MapSuite.AndroidEdition]] | ||
