plot_point
plot_point [2015/09/28 06:56]
plot_point [2015/09/28 09:49] (current)
-====== ​Plot_Point ​======+====== ​Plot Point ======
 The **Plot Point** feature allows you to locate a set of coordinates on the map and mark them with a balloon-style marker. Coordinates can be input using a variety of different formats, including the local coordinate system based on your [[Map Projection]]. ​ The **Plot Point** feature allows you to locate a set of coordinates on the map and mark them with a balloon-style marker. Coordinates can be input using a variety of different formats, including the local coordinate system based on your [[Map Projection]]. ​
 ===== Video Overview ===== ===== Video Overview =====
-{{#​ev:​youtubehd|e4QMJg04wTo|720||How to plot a point on your map.}}+{{youtube>e4QMJg04wTo?720||How to plot a point on your map.}}
 ===== Plotting a Point ===== ===== Plotting a Point =====
Line 27: Line 27:
 To remove a plotted point'​s balloon marker from your map, hover over the balloon marker, which will reveal a red "​X"​ button in the upper right corner of the balloon. ​ Then click the "​X"​ to remove the marker. To remove a plotted point'​s balloon marker from your map, hover over the balloon marker, which will reveal a red "​X"​ button in the upper right corner of the balloon. ​ Then click the "​X"​ to remove the marker.
-[[Category:​General]] [[Category:​Articles with Video]]
plot_point.1443423412.txt.gz ยท Last modified: 2015/09/28 09:49 (external edit)
