map_suite_wpf_desktop_edition_labeling_samples
map_suite_wpf_desktop_edition_labeling_samples [2015/09/07 09:51]
admin [Map Suite Wpf Desktop Edition Labeling Samples ====== Draggable Labels]
-====== Map Suite Wpf Desktop Edition Labeling Samples ====== Draggable Labels ====
-<div sampleitem>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Draggable Labels.jpg?​300x180}}
-[[Source_Code_WpfDesktopEditionSample_DraggableLabels CS 101013.zip|View Source]] | {{:​File:​WpfDesktopEditionSample_DraggableLabels_CS_20140617.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-[[Map Suite Samples Applies To|Applies To: Web \ Wpf]]
-In this wpf project, we are going to show how to place labels from a shapefile into a SimpleMarkerOverlay. Using the DragMode property of the SimpleMarkerOverlay,​ the user can then drag the labels to place them at the desired location for the most pleasing labeling effect. This project will be later completed to show how to save the state of the dragged labels from the SimpleMarkerOverlay and reload them.
-==== Labeling based on size ====
-<div sampleitem>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Edition Sample Labeling based on size.jpg?​300x180}}
-[[[Source_Code_DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|View Source]] |
-{{:​File:​DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-[[Map Suite Samples Applies To|Applies To: Desktop \ Web \ Silverlight \ Services \ Wpf \]]
-==== MultiLine Labeling ====
-<div sampleitem>​
-{{wpfedition:​codesamples:​Map Suite Wpf Desktop Sample MultiLine Labeling.jpg?​300x180}}
-[[[Source_Code_WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|View Source]] |
-{{:​File:​WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-==== Multiple Labels ====
-<div sampleitem>​
-{{wpfedition:​codesamples:​Picture Map Suite Samples Multiple Labels.png?​300x180}}
-[[[Source_Code_DesktopEditionSample_MultipleLabels_CS_100128.zip|View Source]] |
-{{:​File:​DesktopEditionSample_MultipleLabels_CS_100128.zip|C#​ Download}} | [[Map Suite Samples Alternate Languages | Need it in another language?]] \\ \\
-This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like "​[[ColumnName1]][ColumnName2]..."​ and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.\\ ​  \\ For more information you can see the discussion forum post below: ​ \\ http://​gis.thinkgeo.com/​Support/​DiscussionForums/​tabid/​143/​aff/​21/​aft/​6955/​afv/​topic/​Default.aspx
map_suite_wpf_desktop_edition_labeling_samples.1441619483.txt.gz · Last modified: 2015/09/07 09:51 by admin
