map_suite_windows_phone_edition_spatial_functions_samples [2015/09/18 08:39] admin [Distance Query on Projected Layers] |
| - | ====== Map Suite Windows Phone Edition Spatial Functions Samples ====== | ||
| - | ==== Clipping On Line Layer ==== | ||
| - | <div screenshot> | ||
| - | {{windowsphoneedition:codesamples:Map Suite Wpf Desktop Edition Sample Clipping On Line Layer.jpg?300x180}} | ||
| - | <div content> | ||
| - | [[Source_Code_WpfDesktopEditionSample ClippingOnLineLayer CS 110210.zip|View Source]] | ||
| - | {{:File:WpfDesktopEditionSample ClippingOnLineLayer CS 110210.zip|C# Download}} | ||
| - | [[Map Suite Samples Applies To|Applies To: WindowsPhone \ Desktop \ Web \ Silverlight \ Services \ Wpf ]] | ||
| - | ==== Create Inner Ring ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample Create InnerRing.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_CreateInnerRing_CS_100811.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_CreateInnerRing_CS_100811.zip|C# Download}} | ||
| - | ==== Distance Query on Projected Layers ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample Distance Query On Projected Layers.png?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample DistanceQueryOnProjectedLayers CS 101228.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample DistanceQueryOnProjectedLayers CS 101228.zip|C# Download}} | ||
| - | ==== FeatureIdsToExclude ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample FeatureIdsToExclude.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_FeatureIdsToExclude_CS_100519.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_FeatureIdsToExclude_CS_100519.zip|C# Download}} | ||
| - | ==== Get Feature Clicked On(Web) ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Web Edition Sample Get Feature Clicked On Web.jpg?300x180}} | ||
| - | [[Source_Code_WebEditionSample_GetFeatureClickedOn_CS_100715.zip|View Source]] | ||
| - | {{:File:WebEditionSample_GetFeatureClickedOn_CS_100715.zip|C# Download}} | ||
| - | [[Map Suite Samples Applies To|Applies To: WindowsPhone \ Web \ Silverlight ]] | ||
| - | ==== Get Feature Clicked On(Web)2 ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample Get Feature Clicked On Web2.jpg?300x180}} | ||
| - | [[Source_Code_WebEditionSample_GetFeatureClickedOn2_CS_100726.zip|View Source]] | ||
| - | {{:File:WebEditionSample_GetFeatureClickedOn2_CS_100726.zip|C# Download}} | ||
| - | ==== Intersect Line ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample Intersect Line.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_IntersectLine_CS_100728.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_IntersectLine_CS_100728.zip|C# Download}} | ||
| - | ==== Polygon Shapes To Multipolygon Shapes ==== | ||
| - | {{windowsphoneedition:codesamples:Map_Suite_Wpf_Desktop_Edtion_Sample_Polygon_Shapes_To_Multipolygon_Shapes.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample_PolygonShapesToMultipolygonShape_CS_101126.zip|View Source]] | ||
| - | {{:File:WpfDesktopEditionSample_PolygonShapesToMultipolygonShape_CS_101126.zip|C# Download}} | ||
| - | ==== Sweep Angle Desktop ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample Sweep Angle Desktop.jpg?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_SweepAngle_CS_100506.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_SweepAngle_CS_100506.zip|C# Download}} | ||
| - | {{page>map_suite_services_edition_spatial_functions_samples}} | ||
