map_suite_windows_phone_edition_labeling_samples [2015/09/18 01:55] admin |
| - | ====== Map Suite Windows Phone Edition Labeling Samples ====== | ||
| - | ==== Labeling based on size ==== | ||
| - | <div screenshot> | ||
| - | {{windowsphoneedition:codesamples:Map Suite Silverlight Edition Sample Labeling based on size.jpg?300x180}} | ||
| - | <div content> | ||
| - | [[Source_Code_DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_LabelingBasedOnSize_CS_100608.zip|C# Download}} | ||
| - | [[Map Suite Samples Applies To|Applies To: WindowsPhone \ Desktop \ Web \ Silverlight \ Services \ Wpf ]] | ||
| - | ==== MultiLine Labeling ==== | ||
| - | {{windowsphoneedition:codesamples:Map Suite Wpf Desktop Sample MultiLine Labeling.jpg?300x180}} | ||
| - | [[Source_Code_WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|View Source]] | ||
| - | {{:File:WpfDesktopEditionSample MultiLineLabeling CS 110316.zip|C# Download}} | ||
| - | ==== Multiple Labels ==== | ||
| - | {{windowsphoneedition:codesamples:Picture Map Suite Samples Multiple Labels.png?300x180}} | ||
| - | [[Source_Code_DesktopEditionSample_MultipleLabels_CS_100128.zip|View Source]] | ||
| - | {{:File:DesktopEditionSample_MultipleLabels_CS_100128.zip|C# Download}} | ||
| - | This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like "[ColumnName1][ColumnName2]..." and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.\\ \\ For more information you can see the discussion forum post below: \\ http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/6955/afv/topic/Default.aspx \\ | ||
| - | {{page>Map Suite Services Edition Labeling Samples}} | ||
